oil pressure gone bad.. *HELP*
i dont know wussup with it anymore. i have a autometer oil pressure gauge and when i crank to ignition the needle goes straight to 100( it's from 0-100).. did i do something wrong. everything is hooked up right. got a good ground, ignition goes to ignition, and sender goes to the sender on the oil pressure unit that came with the kit. did i blow the sender or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23vtec_dc2 »</TD></TR><TR><TD CLASS="quote">i dont know wussup with it anymore. i have a autometer oil pressure gauge and when i crank to ignition the needle goes straight to 100( it's from 0-100).. did i do something wrong. everything is hooked up right. got a good ground, ignition goes to ignition, and sender goes to the sender on the oil pressure unit that came with the kit. did i blow the sender or something? </TD></TR></TABLE>
Sound like the sender wire is grounded somewhere. Try disconnecting it from the sender and see what happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23vtec_dc2 »</TD></TR><TR><TD CLASS="quote">without sender, it doesn't work.. it clicks over to 100 even without ground wire. </TD></TR></TABLE>
What does it do if you disconnect the sender wire from the back of the gauge?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
What does it do if you disconnect the sender wire from the back of the gauge?</TD></TR></TABLE>
then basically it doesn't work if i do that... as of today, i got a copper extention so that i can actually tighten up the sender on the block. because i just hand tighen it and it was leaking oil.. but odd thing is, it doesn't react anymore.. everythings connected but it plays as if it's not even on anymore.. i'm lost.. someone got any clue to what's going on?
then basically it doesn't work if i do that... </TD></TR></TABLE>
It sounds like a problem with the sender wire then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23vtec_dc2 »</TD></TR><TR><TD CLASS="quote">u sure? </TD></TR></TABLE>
If what you are telling me is true. If the gauge shows high presure with the wire disconnected form the sensor and goes to 0 when disconnected at the gauge, your sender wire is grounded somewhere.
7rrivera7
Oct 10, 2007 12:15 PM
Attoir
May 20, 2006 09:13 AM
a1320honda
10
May 22, 2004 03:56 PM
