EG sidemarker wiring....?? my stanleys have 3 leads????
Old Mar 15, 2004 | 05:30 PM
JD95hatch's Avatar
Default EG sidemarker wiring....?? my stanleys have 3 leads????
I got my sidemarkers today...advertised as stanleys...labeled as stanleys and was shipped from japan but instead of having 2 leads per marker one has 3 and one has 2
someone told me stanleys only come with 2 wires but i wouldnt know how they wired up the 3rd wire.
can anyone give me some info??
thanks
Old Mar 15, 2004 | 05:39 PM
JD95hatch's Avatar
bump for some hlep
Old Mar 15, 2004 | 05:40 PM
JDMlyfestyle's Avatar
search is your friend has been covered plenty of times as well as the correct placement of the sidemarkers
Old Mar 15, 2004 | 05:42 PM
JD95hatch's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">search is your friend has been covered plenty of times as well as the correct placement of the sidemarkers</TD></TR></TABLE>
i searched throught pleanty of placements...but nothign helped with what the additional wire is for....
Old Mar 15, 2004 | 05:45 PM
soundbomber's Avatar
Default Re: (JD95hatch)
both wires can be used as a signal, just splice them both into the turn signal wire, the black one is for ground. don't worry about the 3rd wire
Old Mar 15, 2004 | 05:49 PM
well i believe that there should be 3 wires on both of them.
1 ground
1 power
1 signal
Old Mar 15, 2004 | 05:51 PM
JD95hatch's Avatar
Default Re: (soundbomber)
most writeups i hear about are mentioned with only 2 wieres
Old Mar 15, 2004 | 05:54 PM
Default Re: (civic_rice)
when i did mine, i was in the same situation, one harness with 2 wires, the other with 3, if you tap the 2 + wires that you have, in your case green, it will still work if you splice them into the same wire. you can test it if you don't believe me
JD95hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rice &raquo;</TD></TR><TR><TD CLASS="quote">I believe....
one will illuminate the sidemarker (as long as the vehicle is on)
one will make the sidemarker blink (to the turn signal)
one wire is ground.</TD></TR></TABLE>
so are you saying that the corners will be on when lights are on but when i signal it will flash?
Old Mar 15, 2004 | 05:55 PM
Yup the signal wire allows it to blink. and the sidemarker will turn on as soon as you turn on your lights.
Old Mar 15, 2004 | 05:56 PM
JD95hatch's Avatar
so it wont matter if i run that extra wire into the corners or if i left it out.
Old Mar 15, 2004 | 05:59 PM
the thing is, on your harness, both of those green wires are running into the same pin, so it is the same wire. you can only put one signal into it
Old Mar 15, 2004 | 06:00 PM
JD95hatch's Avatar
makes sense but just needed to be sure....thanks HT.
Old Mar 15, 2004 | 06:10 PM
holla, is that pharoah monche in your avatar?
Old Mar 16, 2004 | 12:41 PM
JD95hatch's Avatar
hahah.....no but pharoah monch did work with him....its kanye west
"Pysa"
Sep 26, 2006 04:05 PM
blazeone44
Mar 7, 2006 12:03 PM
vxnine
Jan 26, 2005 11:07 PM
S@nt0s
Jan 16, 2004 06:24 AM
sirIIking
Oct 7, 2003 02:00 PM
