EG sidemarker wiring....?? my stanleys have 3 leads????
I got my sidemarkers today...advertised as stanleys...labeled as stanleys and was shipped from japan but instead of having 2 leads per marker one has 3 and one has 2
someone told me stanleys only come with 2 wires but i wouldnt know how they wired up the 3rd wire.
can anyone give me some info??
thanks
thanks
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">search is your friend has been covered plenty of times as well as the correct placement of the sidemarkers</TD></TR></TABLE>
i searched throught pleanty of placements...but nothign helped with what the additional wire is for....
Re: (JD95hatch)
both wires can be used as a signal, just splice them both into the turn signal wire, the black one is for ground. don't worry about the 3rd wire
Re: (civic_rice)
when i did mine, i was in the same situation, one harness with 2 wires, the other with 3, if you tap the 2 + wires that you have, in your case green, it will still work if you splice them into the same wire. you can test it if you don't believe me
Re: (civic_rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rice »</TD></TR><TR><TD CLASS="quote">I believe....
one will illuminate the sidemarker (as long as the vehicle is on)
one will make the sidemarker blink (to the turn signal)
one wire is ground.</TD></TR></TABLE>
so are you saying that the corners will be on when lights are on but when i signal it will flash?
Re: (JD95hatch)
the thing is, on your harness, both of those green wires are running into the same pin, so it is the same wire. you can only put one signal into it
vxnine
01-26-2005 11:07 PM
