Strange Noise while letting off throttle
Old Mar 15, 2004 | 05:25 PM
DrunkNRacer's Avatar
Default Strange Noise while letting off throttle
While im driving.. sometimes, when I let off the gas.. I hear this strange knocking noise in my chasis somewhere.. it only happens when I let off the gas.. any light application of the gas pedal cancels it out.. this is very strange. It sounds like a woodpecker under my car..
Old Mar 15, 2004 | 05:30 PM
fw190bvi's Avatar
Default Re: Strange Noise while letting off throttle (DrunkNRacer)
perhaps part of the dash has come unclipped.......??......there was a recall on the stock exhaust because of a ratteling noise, but i doubt that applies to you......i would check to make sure all interor parts are clipped in, and that all ur susp. bolts are tight
Old Mar 15, 2004 | 05:32 PM
Steve04SVT's Avatar
Check your exhaust system. Might be anything from a bad or loose bolt, to a bad a-pipe (pipe that connects exhaust manifold to b-pipe under car). Might also be part of the exhaust system hitting the bottom of the car or something. Best bet would be to get under the car and check it out.
Old Mar 15, 2004 | 06:15 PM
2+2=5's Avatar
Default Re: Strange Noise while letting off throttle (Steve00GSR)
engine, tranny mount
mikog575
Apr 13, 2018 09:34 PM
MrZee
Oct 21, 2013 11:37 AM
LudeChild
Jan 13, 2005 06:56 PM
96AccordExCpe
Jun 25, 2003 11:33 AM
