1990 Accord Coolant leak
Old Mar 15, 2004 | 05:02 PM
mhouston's Avatar
Default 1990 Accord Coolant leak
My accord has a coolant leak. It will leak some coolant once in a while
after being driven. Do these radiators develop cracks in them. The car has 167,000
miles on it. thanks for the info
Matt
Old Mar 15, 2004 | 05:08 PM
The_Todd's Avatar
Farts in the shower
Default Re: 1990 Accord Coolant leak (mhouston)
Yes honda unfortunatly doesn't make really great radiators...I would run a leak test and make sure its your radiator before you replace it. I would check hoses top and bottom along with your clamps. If indeed your radiator is leaking replace with a fluidyne or something of the effect for about the same price w/better construction.
Old Mar 15, 2004 | 05:51 PM
jwogen1's Avatar
Default Re: 1990 Accord Coolant leak (VRDrvr)
anything other than plastic if it is cracked and leaking
Old Mar 15, 2004 | 06:26 PM
iam7head's Avatar
Default Re: 1990 Accord Coolant leak (jwogen1)
ai..jb weld time if you dont plan to change the whole rad.
Old Mar 15, 2004 | 08:36 PM
John Gordon's Avatar
I have a '90 Accord EX with 260K miles. I had to replace the readiator twice. Both only lasted 100-110K miles.
Like the other poster said, have a shop do a pressure test. They should isolate the problem.
Old Mar 16, 2004 | 11:31 AM
briq4's Avatar
Default Re: 1990 Accord Coolant leak (John Gordon)
93 Accord here 305,000 miles original Nippondenso (or could be just denso I forget what is written on it and it's raining and snowing out so I'm not going to go check ) Radiator, only leak that happened was that the drain **** gasket went bad, got a new one at honda for like 4 bucks and still workin fine. Just something you might want to check, it leaked a TINY bit for a very long time and I didn't realize it becuase it apparently only leaked under pressure (engine hot) so when it was cool the drip would be gone.
PeteB
Aug 14, 2018 12:43 PM
Mason Edmison
Aug 7, 2017 03:12 AM
tymonroe
Jul 28, 2015 02:42 PM
shanked
Oct 13, 2014 05:47 AM
Deshmahn
Feb 25, 2011 12:39 PM
