only rear sway bar??
Old Mar 15, 2004 | 04:22 PM
made in JAPAN's Avatar
Default only rear sway bar??
i plan on autocrossing my DA this summer, and i am in the market for suspension technique sway bars and a strut tower bar. Most people suggest only using the rear susp. tech. bar, because the front doesnt do much. is this true, or should i get both bars?? i am also looking at the Neuspeed 4pt. front strut bar, are there any other alternatives to this bar in the same price range that offer more support like a 3pt. bar???
Old Mar 15, 2004 | 04:53 PM
doublejz's Avatar
Default Re: only rear sway bar?? (made in JAPAN)
anything that connectors to points together on your chasis can only improve it
Old Mar 15, 2004 | 05:02 PM
silverCRXTC's Avatar
Default Re: only rear sway bar?? (doublejz)
the stock front bar is pretty big while the rear stock is tiny (15mm in a EF) i have the st bars for my rex and they are alot bigger than stock, but my car is still on blocks so i cant comment on performance yet.
Old Mar 15, 2004 | 05:18 PM
Sliced Beard's Avatar
Default Re: only rear sway bar?? (silverCRXTC)
the front sway bar does do a whole lot
for one it helps the car resist having excessive amounts of body roll
but if the balance of the front and rear is too differentthen it will either push real hard or the rear end will break loose too easily
nek9
Suspension & Brakes
Jun 20, 2010 03:01 PM
520lbGIANT
Suspension & Brakes
10
Aug 26, 2007 02:43 AM
fluke83
Jul 6, 2004 03:13 AM
spork sport
Feb 22, 2002 03:51 PM
