flashing CEL and the R shakes: wtf
a week ago or so the CEL started flashing now and then and at 10-30mph the R shakes like crazy when it's cold and I also hear some ticking sounds coming from the engine bay (as if something is hitting against something) on the driver's side...then when it warms up it gets better...
This does not happen at idle, only when accelerating and at full throttle I hear some other weird sounds ...I checked the O2 sensor, but it's not that...
Now I'm not asking anyone to guess what it is, but maybe if someone had some idea I would appreciate it since the Honda dealer didn't even figure it out
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackberry »</TD></TR><TR><TD CLASS="quote">Oops I didn't mean to add a poll...
Worst yet, an open poll.
<---will refrain from adding something totally off topic to an open poll. This is a one time deal though.
Edit - No idea what could be wrong with your car.
</TD></TR></TABLE>Worst yet, an open poll.
I checked the codes, but since my stock ECU is modified (yes the stock one) the code system doesn't work anymore...I will find someone to lend me one so I can check but in the meantime I wanted to see if anyone had experienced the same...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackberry »</TD></TR><TR><TD CLASS="quote">since my stock ECU is modified (yes the stock one) the code system doesn't work anymore...</TD></TR></TABLE>
So, if you had it to do over again, would you have modified your ECU the way you did?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">
RMAOL
RMAOL
No I haven't run through puddles nor overrevved...and yes I have the rev limiter set at about 9k rpm...
And to answer the other questions no I don't regret it at all...the ecu is similar to the mugen one, but I have to say that on my basically stock R it runs great! Alex Woods who has a 245 whp n/a R made it...
But in any case I don't think it's the ecu causing this problem...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">Sputtering.. MAP sensor?
tapping, etc noises.. Valve Lash?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackberry »</TD></TR><TR><TD CLASS="quote"> no I don't regret it at all...the ecu is similar to the mugen one, but I have to say that on my basically stock R it runs great! Alex Woods who has a 245 whp n/a R made it...
But in any case I don't think it's the ecu causing this problem...</TD></TR></TABLE>
then why didn't you just get a mugen program instead of ******* everything else up?
what are you dynoing?
who cares about alex or tiger woods.
its not the ecu causing the problem..its the ecu preventing you from fixing it
solerizr
Feb 25, 2007 10:15 AM
