o2? help!
Old Mar 15, 2004 | 12:22 PM
joesefcivic's Avatar
Default o2? help!
ok i got my two o2's place on my header at the 1-4 position and 2-3 position does any one now wich o2 goes to the 1-4 and 2-3. the one plug is green and the other is white. just wanting to make sure that i have them correct.
if these were not corect then would this make me have a slight bogging of the motor? its only at a constant speed that it does it, and does not loose power at all. just feels wierd. or could this be a vacum problem?
Old Mar 15, 2004 | 03:33 PM
crxtreme89h's Avatar
Default Re: o2? help! (joesefcivic)
Try swapping the wires. The bogging could be from a number of things. If it is a fresh swapped motor then check your vacuum hoses, throttle cable, coolant level. I fixed all of these on my car and it runs better.
Who would have thought coolant? LOL
Maybe I'm just lucky so far on that one.
Edit: Now that I re-read your post I noticed you said slight bogging at constant driving. Not accelerating, but just driving at a set MPH I get the slight bogging still. It's not much really. I just hit the gas and it goes away. I don't know what is causing this situation.
Old Mar 15, 2004 | 05:21 PM
yah thats exactly what i get. its not when i excelerate its when im at a constant speed!
thanks for the input though
beanbag
Dec 2, 2012 03:02 PM
wallendiaz
Nov 18, 2012 02:51 PM
bmoreb18c1
Aug 13, 2012 01:14 AM
95sloweg
Nov 9, 2007 05:10 PM
psx_pat
Jun 24, 2005 07:38 PM
