arp main stud questions
Old Mar 15, 2004 | 12:02 PM
MrBui's Avatar
Default arp main stud questions
would i have to line bore my block if i put the main studs in? put it on a friends block and it was too tight of a fit. or are these supposed to be just remove and replace kinda deal.
Old Mar 16, 2004 | 04:50 AM
MrBui's Avatar
Default Re: arp main stud questions (n20need4vtec)
anybody?
Old Mar 16, 2004 | 07:10 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n20need4vtec &raquo;</TD></TR><TR><TD CLASS="quote">would i have to line bore my block if i put the main studs in? put it on a friends block and it was too tight of a fit. or are these supposed to be just remove and replace kinda deal.</TD></TR></TABLE>
what do you mean too tight ? did you use stock main bolts then tried the main studs and it was too tight ?
there is no reason to line bore from using main studs, they are simply replacing the main bolts and having less stretch/more clamping force.
Greg
Old Mar 16, 2004 | 12:28 PM
MrBui's Avatar
Default Re: arp main stud questions (CHEETAH)
well arp recommends torqueing them down more than stock specs
Old Mar 16, 2004 | 01:22 PM
turbo96wr's Avatar
the main stud bolts should be torque to stock specs the reason your crank don't turn is because you torqued them beyond spec, i only use AEBS studs to stock torque and never had problems.
Old Mar 16, 2004 | 01:35 PM
LudeyKrus's Avatar
Even if you overtorque them, it would not make the clearances tighter. Sounds like either the bearings are too tight or you are just having trouble sitting the crank down into the mains. Try again.
97twodoor
10
Mar 13, 2009 04:17 PM
TeggieeTuner
Feb 14, 2009 09:58 AM
totsie7944
Feb 20, 2008 07:27 PM
Topdawgg
Mar 14, 2007 01:35 AM
dumpeDc2
Nov 6, 2004 12:24 PM
