jdm p13 questions...
Old Mar 15, 2004 | 10:43 AM
NoLipRacen's Avatar
Default jdm p13 questions...
im planning on buying a jdm p13 for my usdm 96 vtec sometime soon and i was wondering about a few things...
1. is there a way without chipping to remove the speed limiter? what are my options?
2. other than the harness and ecu itself is there anything else i must remove/modify?
3. what are the differences between the 2 ecus? other than the whole obd1 thing...
thanks guys!
Old Mar 15, 2004 | 10:49 AM
jdmlude_dude's Avatar
Default Re: jdm p13 questions... (NoLipRacen)
The speed limiter can only be lifted my chipping the ecu or having it reprogramed. If you want to spend the extra money, send it to Hondata. As for the rest, all you will need is an OBD2/OBD1 conversion harness. As for differences. Not 100% sure. The speed limiter is one. And i believe the fuel ratios and everything are a bit different. I do not know about usdm ecu's, but my vtec engages at 5200 with my p13.
Old Mar 15, 2004 | 01:22 PM
NoLipRacen's Avatar
Default Re: jdm p13 questions... (jdmlude_dude)
so there is no messing with the resistor box or anything?
Old Mar 15, 2004 | 01:31 PM
H22A EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude_dude &raquo;</TD></TR><TR><TD CLASS="quote">The speed limiter can only be lifted my chipping the ecu or having it reprogramed. If you want to spend the extra money, send it to Hondata. As for the rest, all you will need is an OBD2/OBD1 conversion harness. As for differences. Not 100% sure. The speed limiter is one. And i believe the fuel ratios and everything are a bit different. I do not know about usdm ecu's, but my vtec engages at 5200 with my p13.</TD></TR></TABLE>
you can get a fields VTEC controller to kick out the limiter
Old Mar 15, 2004 | 04:08 PM
Default Re: jdm p13 questions... (H22A EG6)
awsome, i didnt know that.
MadCityLude
Nov 8, 2005 08:16 AM
mprelude
Apr 26, 2005 05:07 AM
colt45
Jan 6, 2005 01:33 AM
Rev-gasm
Oct 8, 2002 12:44 AM
555R
Dec 28, 2001 09:37 AM
