how many have just "bolted on" a block girdle?
Old Mar 15, 2004 | 09:55 AM
Full-Race Geoff's Avatar
Default how many have just "bolted on" a block girdle?
I am interested in knowing how many people have just put a block girdle on their motors without checking the mains?
If you have, have you torn your engine down since and what did the #3 mains look like?
thanks
Old Mar 15, 2004 | 11:02 AM
94si94cx's Avatar
Default Re: how many have just "bolted on" a block girdle? (Full-Race Geoff)
Are you referring to motors in which the block girdle did not originally come?
Old Mar 15, 2004 | 11:14 AM
Default Re: how many have just "bolted on" a block girdle? (94si94cx)
that is correct
Old Mar 15, 2004 | 11:54 AM
94si94cx's Avatar
I'd also be interested in finding out. I've only been blessed with stock block girdles thus far.
Old Mar 15, 2004 | 12:52 PM
chad's Avatar
Moderator
put a gsr griddle on my b20 block....then had it line bored....worked great!
Old Mar 15, 2004 | 01:25 PM
dsadas89das78934's Avatar
i'm also curious about this.... but fortunately for me, my d16 came stock with a girdle
Old Mar 15, 2004 | 06:05 PM
DavidR's Avatar
I put on a Z10, had the mains/girdle machined for dowels. 10k later, 2, 3, 4 main bearings looked pretty damn good. 1 and 5 looked horrible. They were super bright, but had not yet started getting into the lower materials.
edit: I did not line bore it, the machine shop said it was straight. I'm not going back there again. Next time, I am probably using a 5 main girdle cap anyway....
DA9tothewheel
Engine Machining & Assembly
Aug 21, 2016 02:48 AM
HYREV2NR
Nov 23, 2007 10:18 PM
JDM00SI
Nov 1, 2005 10:53 AM
Full-Race Geoff
Apr 10, 2004 07:50 AM
