my ITR baffled pan , done the correct way.
Old Mar 15, 2004 | 09:44 AM
Doctor CorteZ's Avatar
Default my ITR baffled pan , done the correct way.
this is how I baffled my ITR pan.
with the doors closed it acts as a standard baffled pan , but unlike the fixed setups it allows much faster drainback and is designed to help oil get back to the pickup as quickly as possible.
if you look at the OEM pan design it only has one drainback hole , so all the oil could potentially be stuck away from the pickup for quite some time , under cornering and acceleration its going to stay on top of the baffles until the load direction changes , with my pan the trap door will open and allow instant drainback.
you can see the notches that direct oilflow back to the pickup , where it belongs.
both doors operate seperately and live in a well lubricated environment so wear is not a concern in the least.
operation is simple , under hard accel/decel the oil is forced against the door which closes to keep the oil near the pickup acting as a fixed baffle , as soon as the load changes the door closes and keeps the oil at the pickup preventing starvation.
I charge 125.00 if you send me your pan , turn around time is 1-2 work days.
fixed baffles are also available for 75.00 if you send me your pan.
D series / H series , alum and steel pans are also no problem.
Old Mar 15, 2004 | 09:47 AM
mstewar's Avatar
Default Re: my ITR baffled pan , done the correct way. (Doctor CorteZ)
pretty..
that the one for my car?
Old Mar 15, 2004 | 09:48 AM
Chris93Si's Avatar
Very interesting stuff and looks like great quality work
< Who saw some of doc's custom fabbed stuff and was amazed at the craftsmanship.
Old Mar 15, 2004 | 09:49 AM
Default Re: my ITR baffled pan , done the correct way. (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
that the one for my car? </TD></TR></TABLE>
jes.
Old Mar 15, 2004 | 09:51 AM
mstewar's Avatar
Default Re: my ITR baffled pan , done the correct way. (Chris93Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">Very interesting stuff and looks like great quality work
&lt; Who saw some of doc's custom fabbed stuff and was amazed at the craftsmanship.</TD></TR></TABLE>
definitely impressive craftsmenship..
Old Mar 15, 2004 | 09:53 AM
Bbasso's Avatar
So everytime you make a turn your going to hear the 'doors' close?
Really looks like a nice design!
Old Mar 15, 2004 | 09:56 AM
thk's Avatar
thk
Members Only
I guess one of those trap doors will always be semi open if a Spoon magnetic drain plug is used, eh?
RTW DC2R's Avatar
I understand the concept, but Im not really sure what Im looking at in the pics. I cant tell what you added or changed because everything is repainted black. Care to draw some circles where you made the changes?
Old Mar 15, 2004 | 10:00 AM
Default Re: my ITR baffled pan , done the correct way. (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">So everytime you make a turn your going to hear the 'doors' close?
its more accel/decel actually , the pan already has small lateral baffles in it.
it seems the main cause of starvation is two simultaneous movements , IE : hard accel and hard turning...
Old Mar 15, 2004 | 10:02 AM
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">I cant tell what you added or changed because everything is repainted black. </TD></TR></TABLE>
OEM stock pan , drainplug is in the back.
this was nearing completion and before paint.
Old Mar 15, 2004 | 10:07 AM
RTW DC2R's Avatar
good ish
Thanks
Old Mar 15, 2004 | 10:08 AM
Default Re: my ITR baffled pan , done the correct way. (thk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">I guess one of those trap doors will always be semi open if a Spoon magnetic drain plug is used, eh?</TD></TR></TABLE>
no.
more clearence can be achieved for larger magnetic drain plugs , it just need to be requested.
Old Mar 15, 2004 | 10:41 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">
no.
more clearence can be achieved for larger magnetic drain plugs , it just need to be requested.</TD></TR></TABLE>
awww.. damn! I can't run my bling bling drain plugs!
Old Mar 15, 2004 | 11:04 AM
Smitdog's Avatar
Jamie with workmanship that is always Impressive! SHould I sell this m0000gen pan?
Old Mar 15, 2004 | 11:12 AM
Kengs's Avatar
Default Re: my ITR baffled pan , done the correct way. (Smitdog)
No doubting Jamie's fabrication skillz
Old Mar 15, 2004 | 11:25 AM
mrlegoman's Avatar
Default Re: my ITR baffled pan , done the correct way. (kengs)
When can you install the lexan window in my pan so I can show off the trap-doors for show point?
Old Mar 15, 2004 | 11:45 AM
B18CXr's Avatar
Old Mar 15, 2004 | 12:22 PM
Mr Furball's Avatar
Props to his teacher,
looks like your skills are becoming greater my son. NOW come join the dark side with me luke.
Old Mar 15, 2004 | 12:27 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: my ITR baffled pan , done the correct way. (Mr Furball)
you drinkin' while you working on that?
Old Mar 15, 2004 | 12:28 PM
rice_classic's Avatar
As soon as I can drop my pan I'll IM you for your address. You've sold me on this.
Old Mar 15, 2004 | 12:29 PM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">No doubting Jamie's fabrication skillz </TD></TR></TABLE>
Old Mar 15, 2004 | 01:17 PM
Default Re: my ITR baffled pan , done the correct way. (rice_classic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">As soon as I can drop my pan I'll IM you for your address. You've sold me on this.</TD></TR></TABLE>
good stuph.
Old Mar 15, 2004 | 02:43 PM
canuckr's Avatar
Goot shet
Old Mar 15, 2004 | 03:08 PM
Dr Pooface's Avatar
Default Re: my ITR baffled pan , done the correct way. (canuckr)
Wow.
Nice work man.
