EK swaybar problem!
Old Mar 14, 2004 | 08:35 PM
jimmhatch's Avatar
Default EK swaybar problem!
I just installed my Skunk2 rear swaybar on my EK and when I drive normally, and go over a bump or dip, theres like sqeaky noises coming from the back. I was wondering if this is normal?
Old Mar 14, 2004 | 08:37 PM
lowgman's Avatar
Default Re: EK swaybar problem! (jimmhatch)
Did you lube up the bushings?
Mine squeaks after a couple months, at that point, I just add more lithium grease to the bushing.
EDIT* when you add lube to the bushings, you must remove the bracket/bushing and lube the INSIDE of the bushings.
Old Mar 14, 2004 | 08:46 PM
Gump's Avatar
You can wrap it in teflon tape as well...
Hope you have swaybar reinforcements, wouldn't want to hear about another subframe tearout.
bigG
Mar 23, 2011 03:19 PM
NICB18
Jan 5, 2011 03:27 PM
xbabysharkx
Dec 15, 2010 12:41 PM
manoloek9
Jul 14, 2010 08:44 PM
OEMwh0r3
Jan 19, 2010 05:19 PM
