Rear Sway Bars!
Old Mar 14, 2004 | 07:50 PM
katb16vo's Avatar
Default Rear Sway Bars!
Alright well as most of you guys know, the dx rear LCAs and other models don't have holes to place sway bars, but if you buy aftermarket ones, i heard they use clamps? but not sure, i just replaced my LCA with eg ones but i'm guessing they came from a dx also and they didn't come with holes. but if this is all false i'm guessing you would have to replace the whole LCA with an SI one or another one that has holes?
Old Mar 14, 2004 | 07:54 PM
tominos's Avatar
Default Re: Rear Sway Bars! (katb16vo)
i've always wondered,
for those cars that came without the hole in the lca, can't you just drill a hole for the endlink? it seems like it would work fine.
Old Mar 14, 2004 | 07:56 PM
katb16vo's Avatar
Default Re: Rear Sway Bars! (tominos)
thats what i thought to but i also heard it is bad for the control arm?
Old Mar 14, 2004 | 08:00 PM
tominos's Avatar
bad as in... it will weaken the structural integrity of the lca? anyone care to shed some light on this>?
Old Mar 14, 2004 | 08:22 PM
APEX CRX's Avatar
I think drilling the a hole is a no no. better off buying an aftermarket swar bar that uses a bracket at the end of the LCA. I have a ST rear bar and it has a bracket that uses the bolt for the lower shock. Plus it brings the load out to the end instead of the middle like the stock placement
Old Mar 14, 2004 | 09:05 PM
chadmasterc's Avatar
I guess i lucked out because my 91 dx hatch had the holes and they were threaded, i just had to buy the brackets from honda.
Old Mar 14, 2004 | 09:23 PM
crx98's Avatar
Default Re: Rear Sway Bars! (chadmasterc)
i have crx si rear LCA plus the whole rear sway bar for sale. PM me
Old Mar 14, 2004 | 09:51 PM
EG8R's Avatar
Default Re: Rear Sway Bars! (crx98)
Needs Si RLA ones to use an OEM rear sway bar.
DpSyChO
38
Apr 10, 2013 12:51 PM
rickscrx
Dec 19, 2011 05:08 AM
timmy0tool
Jul 31, 2006 02:52 PM
crxsleeper210
Suspension & Brakes
May 4, 2006 01:27 PM
BIG RICH
Sep 23, 2003 03:20 PM
