1993 ACcord pulls hard to the right?
Old Mar 14, 2004 | 07:29 PM
00CIVICSITEIN's Avatar
Default 1993 ACcord pulls hard to the right?
Hey whats up my 1993 Honda Accord pulls to the right while driving. I had my dad look at it and he said that it is probally the swaybar is bent. I'm not sure what it is.... It also has horrible tire wear on the outside of the passanger side front tire (RIght tire). My dad feels the sway bar is bent and to fix that and that will solve the pulling to the right and the tire wear issue. Modifications = none..Its all stock
Old Mar 14, 2004 | 07:35 PM
fizzbob7's Avatar
Default Re: 1993 ACcord pulls hard to the right? (00CIVICSITEIN)
probably a lot more wrong than a bent swaybar...whatever bent that bar probably bent other stuff or knocked it out pretty bad.....could be bad camber on one side, or bad caster causing it to pull.......if you can, swap the tires on the front from left to right and see if it's affected at all....does it pull the same when the brakes are applied.....look at the pads......do they look about the same on each side and on both sides of the rotor...most pulls end up being a radial pull.....bent front end parts can definitely cause it though....tire wear and pull sounds like alignment problems to me though
Old Mar 14, 2004 | 08:51 PM
New Image's Avatar
I recommend you take a look under the car and examine the suspension. You will at least need new tires and an alignment it sounds. Good luck!
Old Mar 14, 2004 | 08:55 PM
.bagged's Avatar
Default Re: 1993 ACcord pulls hard to the right? (94JDMEG)
Go get an alignment and that will answer some questions..
Curtisg43228
Feb 22, 2015 07:13 PM
accordxdown93
Jan 1, 2013 03:32 PM
Apperson
Aug 31, 2010 08:07 AM
D_TY3
Sep 5, 2007 02:16 PM
emoze
Jun 5, 2007 07:27 PM
