difference between d16a6 and my new d16a1?
Old Mar 14, 2004 | 04:51 PM
dsCRXsi's Avatar
Default difference between d16a6 and my new d16a1?
i have a supercharged d16a6 and im wondering if my supercharger, clutch flywheel, pistons, rods, crank are transferable to my d16a1. And if not what kind of rods pistons and sleeves to i use iim haveing problems finding parts for the d16a1 here in MN.
Old Mar 14, 2004 | 04:52 PM
B2FiNiTY's Avatar
Default Re: difference between d16a6 and my new d16a1? (dsCRXsi)
d16a1 is completely different. It is a DOHC d series motor.
Old Mar 14, 2004 | 05:02 PM
Fobtions's Avatar
Default Re: difference between d16a6 and my new d16a1? (B2FiNiTY)
the mounting positions are different, u will have to customize alot
Old Mar 14, 2004 | 05:14 PM
jedubz's Avatar
Default Re: difference between d16a6 and my new d16a1? (Fobtions)
Yeah that would be a waste, you'd be better off attempting to mate it to a z6 or something like that than a a1, everything is backasswords and it's DOHC.
Old Mar 14, 2004 | 05:18 PM
boosted_zc's Avatar
Some true and false info here. Clutch will work, flywheel won't it's to thin. Pistons and rods will work. The pistons will yield a slightly lower compression in the A1, i have A6 pistons in my ZC, basically the same thing. The mounting thing is correct, the drivers side mount is different, you'll need to modify that. Any D-series exhaust mani will work, intake hell no. D16A1 / ZC intakes are unique, they have a wierd *** bolt pattern, so you'd have to have or make an adapter for the manifold. I think that about covers it. And this isn't "i know a guy who did this" info, i've done all of this first hand.
shredmanant
Sep 24, 2014 04:22 AM
misha
Apr 20, 2009 06:46 PM
hondaluver12
Feb 17, 2009 05:51 PM
99sonicbluegsr
Oct 6, 2004 08:18 PM
89civichatchback
May 2, 2003 12:43 PM
