What die size to rethread lowe ball joint?
Old Mar 14, 2004 | 04:25 PM
DOMKID's Avatar
Default What die size to rethread lowe ball joint?
I need to rethread my lower ball joint nut. Helms says its 12x1.25 but i cant find that size die at any stores. Does anybody know what SAE size will work? or can i use 12x1.5?
thanks.
Old Mar 14, 2004 | 07:27 PM
DOMKID's Avatar
Default Re: What die size to rethread lowe ball joint? (Dominican_Kid)
bump
Old Mar 14, 2004 | 07:48 PM
Discosteak's Avatar
IMO just buy a new ball joint nut. they arent that expensive
Old Mar 15, 2004 | 09:02 AM
DOMKID's Avatar
Default Re: What die size to rethread lowe ball joint? (BADEG6)
yea but i dont have immediate access to a press.
bump
Old Mar 15, 2004 | 09:54 AM
ARIZONA's Avatar
If you don't have a press, no worries.. when you are ready to remove the BJoint, you can pound/punch them out if you aren't concerned with damaging the old one. Then go spent 30 bucks on a new one and carefully punch it in.
I've done it this way a few times.
Old Mar 15, 2004 | 01:01 PM
GARBhatch.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dominican_Kid &raquo;</TD></TR><TR><TD CLASS="quote">I need to rethread my lower ball joint nut. Helms says its 12x1.25 but i cant find that size die at any stores. Does anybody know what SAE size will work? or can i use 12x1.5?
thanks.
</TD></TR></TABLE> I don't understand... Why would you need a press to put on a new castle nut?? In the case you were putting in a new balljoint, then you would. Maybe i'm misreading(but i re-read it a few times..).
Old Mar 16, 2004 | 04:34 PM
Discosteak's Avatar
Default Re: What die size to rethread lowe ball joint? (GARBhatch.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GARBhatch. &raquo;</TD></TR><TR><TD CLASS="quote"> I don't understand... Why would you need a press to put on a new castle nut?? In the case you were putting in a new balljoint, then you would. Maybe i'm misreading(but i re-read it a few times..).</TD></TR></TABLE>
Im getting the same vibe
Old Mar 16, 2004 | 04:37 PM
BatuKing's Avatar
He might need to thread it because he mushroomed it when the hammered it out to get the knuckle freee.
You can find a Die for it at ACE hardware (they tend to carry unsual sizes) and no SAE will not work
Old Mar 17, 2004 | 12:31 AM
DOMKID's Avatar
Default Re: What die size to rethread lowe ball joint? (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">He might need to thread it because he mushroomed it when the hammered it out to get the knuckle freee.
You can find a Die for it at ACE hardware (they tend to carry unsual sizes) and no SAE will not work</TD></TR></TABLE>
exactly. Im going to try them this weekend.
pprowler6
Apr 15, 2008 02:53 PM
EnjoyTheRideDC2
Suspension & Brakes
11
Dec 11, 2006 10:11 PM
EnjoyTheRideDC2
Nov 7, 2006 12:09 PM
PINKS
17
Apr 17, 2006 06:55 PM
