Failed Emission...High NO...any suggestions?
Old Mar 14, 2004 | 04:06 PM
thao4life's Avatar
Default Failed Emission...High NO...any suggestions?
I have a 91 Hf with a 89 D16A6 that failed emissions. It passed at 15mph but failed at 25mph due to high NO. (Mods: AEM Intake, 1 Piece DC D series Header)
Timing: 18 BTDC
O2 sensor - a few months old
Cat - Half a year old
Comprehensive Visual Inspection = Pass
Functional Check= Pass
Emission Test= Fail
Emissions numbers:
15mph
HC = 66 (max=134) pass
CO = .31 (max=.82) pass
NO = 833 (max=847) pass
25mph (Fail)
HC= 17 (max=108) pass
CO= .01 (max=.71) pass
NO= 925 (max=786) failed
Any Suggestions? What might be the cause of high NO?
Old Mar 14, 2004 | 04:09 PM
94cxHybrid's Avatar
New User
Default Re: Failed Emission...High NO...any suggestions? (thao4life)
Did the car sit for a long time before the test actually started??
Old Mar 14, 2004 | 04:15 PM
thao4life's Avatar
Default Re: Failed Emission...High NO...any suggestions? (94cxHybrid)
I drove it on the highway for 15 min to warm up the car...but it sat for about 2 hours before they tested the car.
Old Mar 14, 2004 | 04:20 PM
boostedcivicsir's Avatar
Mr. Badwrench
high NO if they mane NOx like in delaware, thats usually when the cylinder temp is too high, usually a stuck closed egr will cause that but since you dont have an egr, try retarding the timming a little bit.
Old Mar 15, 2004 | 10:42 AM
thao4life's Avatar
Default Re: Failed Emission...High NO...any suggestions? (boostedcivicsir)
I don't know about retarding the timing...the smog tech said that timing was good and I should leave it alone. ..
Old Mar 15, 2004 | 10:51 AM
allmotaeg6's Avatar
use a higher octane.. NOx is caused by a number of things and low octane is one of them you might wanna probably change out your cat too
Old Mar 15, 2004 | 11:03 AM
00MRSi's Avatar
Default Re: (pr0ject Eg6)
Trying filling up with premium fuel before the test and drive the car hard on the way there and keep her running. Get that cat nice and hot..
avrfan
May 13, 2015 06:29 PM
langjairicer
May 28, 2010 01:13 AM
intougera
Feb 7, 2005 11:59 AM
kevin96GSR
Apr 26, 2004 09:16 AM
