Help with 96 ls swap into 97 civic dx
Old Mar 14, 2004 | 03:46 PM
chitsard's Avatar
Default Help with 96 ls swap into 97 civic dx
Swap is all done, car runs but very bad, like it's missing. We tested the injectors and it seems to both show positive, do u guys know if the integra injector wiring is different than the civic one?
Modified by chitsard at 6:52 AM 3/19/2004
Old Mar 14, 2004 | 03:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Help with 96 ls swap into 97 civic dx (chitsard)
code 14 is the iac code you need to diag that code. going from a dx to the ls, you went from a 3 wire iac to a 2 wire iac. was that done correctly?
Old Mar 14, 2004 | 05:02 PM
chitsard's Avatar
Default Re: Help with 96 ls swap into 97 civic dx (boostedcivicsir)
I left the orange wire behind, yellow black and black both on ls and civic plugs and are soldered and heat shrinked
Old Mar 14, 2004 | 05:12 PM
EKRacer's Avatar
did you unpin the orange wire on the ecu plug and move the black/blue wire to the other side of it?
Old Mar 14, 2004 | 05:17 PM
chitsard's Avatar
Default Re: Help with 96 ls swap into 97 civic dx (EKRacer)
Can u show me a diagram on which to pin and unpin please, thanks for ur help
Old Mar 14, 2004 | 06:09 PM
chitsard's Avatar
cheechard@hotmail.com thanks!!!
Old Mar 15, 2004 | 08:58 AM
EKRacer's Avatar
hope that pic helps you. I'm doint the same exact swap btw (96LS into 97 DX).
Old Mar 15, 2004 | 01:28 PM
chitsard's Avatar
shiet, thanks for ur help, i did it and it doesn't show a code anymore, but still runs very bad. any idea what it could be?
jdmdreamz414
42
May 24, 2017 01:39 PM
efcivic317
Mar 30, 2014 04:47 AM
kidd_drastic
Nov 12, 2006 03:43 PM
lilredhatch
Mar 15, 2004 06:44 PM
