first gear gettin stuck!
Old Mar 14, 2004 | 03:20 PM
kseriesDC5's Avatar
Default first gear gettin stuck!
like the topic, im just stopped and i try puttin it in first, and thers like a block. I take it out a few times and then it finally goes in, can anyone identify the problem? im tired of people honkin at me! haha.. i have aabout 4200 miles
Old Mar 14, 2004 | 03:54 PM
yzhao17's Avatar
Default Re: first gear gettin stuck! (kseriesDC5)
I had the same problem several times. Just release the clutch when you at N, and then push the clutch to get into gear1. Should be OK.
Old Mar 14, 2004 | 04:09 PM
DIE DIE's Avatar
dude i know exactly what ur talkin about, it pisses me off too. sometimes it goes in perfect, sometimes on the second try, but every once in a while it takes like 3-5 tries then i just finally jam it into first gear. I'm interested in knowing what this is too, even though i don't have an rsx
Old Mar 14, 2004 | 05:04 PM
kseriesDC5's Avatar
Default Re: first gear gettin stuck! (seecretninja)
i dont hold my clutch down usually when im stopped it is in neutral, i dunno... whats wrong it sux and like sometimes ithink it is in and the sound is horrible
Old Mar 14, 2004 | 05:20 PM
PhreeStyleHB's Avatar
try dropping it into 2nd then 1st.
Old Mar 14, 2004 | 05:23 PM
Reborn's Avatar
Reborn_
Default Re: first gear gettin stuck! (PhreeStyleHB)
happens to me too. usually gettin off and back on the clutch or putting it through some other gears works, then my next try in first it goes in just fine
Old Mar 14, 2004 | 07:10 PM
kseriesDC5's Avatar
thanks. ill give it a try hope it works!
Old Mar 14, 2004 | 09:25 PM
DIE DIE's Avatar
yeah, the second to first deal works sometimes. If you just put it as far into first as it'll go then slowly gas it and release the clutch, it will go in most of the time. Kinda scary tho, cause if it doesn't it grinds. um yeah..
Old Mar 14, 2004 | 09:51 PM
SiR_d1's Avatar
Default Re: (seecretninja)
are you guys talking about when your car is at a complete stop and you can't get it into first? or when your rolling or going really slow?
Old Mar 15, 2004 | 01:49 AM
Reborn's Avatar
Reborn_
Default Re: (SiR_d1)
complete stop. sometimes it jus wont go in on the first few tries. doesnt happen very often though, not much of a big deal.
Old Mar 15, 2004 | 06:05 AM
f1nal zeros's Avatar
It is normal bro, everyones tranny does this from time to time. Mine does this and I have had every syncro replaced in the tranny. If this happens again just put it back into neutral, release the clutch then try again.
Old Mar 15, 2004 | 01:45 PM
kseriesDC5's Avatar
Default Re: (f1nal zeros)
thanks! i thought somethin got messed up cuz, it just started happening.
Old Mar 15, 2004 | 01:58 PM
GreenBean's Avatar
Default Re: (kseriesDC5)
If it keeps up, make an appt at your dealer and have a technician test drive the vehicle with you. If it is a "problem" then it will get worse as time goes on.
Old Mar 15, 2004 | 03:32 PM
Jaypee's Avatar
Default Re: (GreenBean)
same problem with my EP3. I just put it in 2nd and push it straight up to 1st to move again.
Old Mar 18, 2004 | 04:32 PM
that guy steveee's Avatar
Default Re: (Jaypee)
its the synchronizers....they suck *****...they are little brass things, vs. the new S2k's carbon steel ones...
Here is how i deal with it!
DO NOT SHOVE IT INTO GEAR WHATSOEVER!!!!!!!!!!! THAT HARMS THE GEARS THEMSELVES!!!
Just simply heel toe ( right foots toe on the brake and right foots heel on the gas) it into gear...by hitting the gas, you speed up the synchros to idling speed, or the engine speed as you decelerate....
the reason it doesnt want to go into gear is because the tranny is at a differnt speed than the motor...the synchros JUST DONT WANT TO ENGAUGE the dog teeth...
again, just gas it a little and watch it SLIDE right into gear.....effertlessly...
.....I learnd this from a IRL driver, he sold me the car at the Honda Dealership...NO JOKE...he told me this technique wile i was having tranny problems, this is how you get around them....
Old Mar 18, 2004 | 04:35 PM
Default Re: (simann)
oh yeah, this is while your left foot is fully pressing in on the clutch pedal....
I thought i might point that out!
Old Mar 18, 2004 | 06:38 PM
singlecamrocket's Avatar
all of you ep3ers should get on the running list of people with tranny probs on ephatch.com they have a petition to honda about it. I agree with simann says just a little throttle and it slides right in.
Old Mar 18, 2004 | 07:04 PM
K20_Rey's Avatar
Default Re: (the giant EP3)
See my sig
Old Mar 18, 2004 | 08:22 PM
Default Re: (K20_Rey)
second that!!!!!
I have already signed the petition....
how many are there so far?
Old Mar 18, 2004 | 08:24 PM
93 total signatures and counting!!!
thats alot of cars guys.....to much for me!
and guys, do try a little touch of throttle when you get stuck out of first gear....it really does work LOL
Old Mar 22, 2004 | 06:28 AM
bump this thread up yo!!!!
Old Mar 22, 2004 | 07:17 AM
minivanman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaypee &raquo;</TD></TR><TR><TD CLASS="quote">same problem with my EP3. I just put it in 2nd and push it straight up to 1st to move again.
yup, stupid syncros!
Old Mar 23, 2004 | 01:20 PM
Big Si Guy's Avatar
Never had this problem w/ my A3.
Since the A2 swap it's happened quite a few times.
Usually takes 2 attempts to go into 1st.
jairobeatz
Oct 27, 2006 12:25 AM
Miz101
May 15, 2005 06:11 AM
Chief Brody
Aug 4, 2004 09:28 PM
NtegraRacR05
May 15, 2003 07:09 PM
tc
Jul 31, 2001 10:10 AM
