Compression test
B16A with CTR(B16B) pistons. What should my compression test numbers be?
180psi
200psi
200psi
180psi
Stock head, not milled, using stock honda headgasket. Thanks
180psi
200psi
200psi
180psi
Well cylinder one and four seem to have an issue. Check your valve lash. And all four are a little low in overall numbers but-
You may have a big primary lobed cam that will affect your numbers
You may have a compresion tester that reads lower than most
Do a leak down and see where the problem is.
