So I just instaled new rotors, pads, and calipers and....
when I go to spin the rotor it is scraping the pads. The piston was backed out completely and the caliper pins are nice and lubed up and slide freely. All the bolts are tourqued to the right specs, all shims and retainers as well as lubricant is on in the right spots. The e-brake is off. What else could this be, or is this normal until you break in the pads and rotors. Also this was done in the rear and the car is still on jackstands cause I have not bled them yet.
i jsut changed my brakes also about two days ago....it will make that noise for a lil bit. but i also sprayed teh "BREAK QUIET" spray on them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbcdb »</TD></TR><TR><TD CLASS="quote">o ok. So the wheels are supposed to just spin freely like a bike rim.</TD></TR></TABLE>
Jigga what? You'll hear the pads rub the disks for a little bit. I think I don't understand what you're asking.
Yes it should spin freely if ur e-brake is off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbcdb »</TD></TR><TR><TD CLASS="quote">...The e-brake is off. What else could this be, or is this normal until you break in the pads and rotors. Also this was done in the rear...</TD></TR></TABLE>
Alexander
Sep 20, 2002 07:59 PM
