ecu problem!
Old Mar 14, 2004 | 01:49 PM
-slow ej-'s Avatar
Default ecu problem!
https://honda-tech.com/zerothread?id=798487
please read and help me
Old Mar 14, 2004 | 02:05 PM
RedlinedVTEC's Avatar
Default Re: ecu problem! (-RsINtEg-)
Are you using a 4-wire o2 sensor? If not swap it out for an oem replacement, don't just go buy one of those 4-wire bosch sensors that you have to splice into your harness, those always result in a code. Or chip the ecu and have the o2 heater disabled.
Old Mar 14, 2004 | 02:10 PM
-slow ej-'s Avatar
Default Re: ecu problem! (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Are you using a 4-wire o2 sensor? If not swap it out for an oem replacement, don't just go buy one of those 4-wire bosch sensors that you have to splice into your harness, those always result in a code. Or chip the ecu and have the o2 heater disabled.</TD></TR></TABLE>
yes i am using a 4 wire o2 sensor from a 95 dx..i also have a 93 integ one too im about to swap in if it is cuz i have a bad o2 can it be the wiring tho:?
Old Mar 15, 2004 | 01:28 PM
-slow ej-'s Avatar
no one?
Crx89joe
Mar 27, 2017 07:56 PM
andyvaj
May 2, 2007 06:28 AM
racingant
12
Nov 11, 2005 06:41 PM
pro547
Aug 11, 2005 03:56 PM
Rywire
Jan 4, 2003 09:53 PM
