CEL
Old Mar 14, 2004 | 01:48 PM
colombian linx's Avatar
Default CEL
I Have a 92 Civic HB w/ 99 GSR running on an OBD-1 ECU(p72), anyways I only get a C.E.L Sometimes, like sometimes it might pop up and sometimes it doesnt turn on. I've read up on how to check it before but when i did it it doesnt work, no C.E.L comes on. can anyone help? the CEL is annoyinng
Old Mar 14, 2004 | 02:07 PM
MonkeyMagic's Avatar
Default Re: CEL (colombian linx)
the cel code should be stored in your ecu... so check for codes even if the light isn't on
good luck!
Old Mar 14, 2004 | 02:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
you probably have an o2 sensor code. it is resetting if you turn the key off. you should be able to check it with the engine running when the light comes on.
Old Mar 14, 2004 | 07:48 PM
how do i do it with the car on??
Old Mar 15, 2004 | 11:09 AM
Scean's Avatar
Default Re: (colombian linx)
the lil blue thing over by your ecu, thicker cord w/ a blue connecter on the end of it/ put a paperclip in both sides of it, and watch the CEL light, long blink=10 short =1, i had 7 shorts a while back, code seven tps sensor.
music462
Apr 10, 2008 05:37 AM
1994hondaprelude_dude
Oct 1, 2006 01:51 PM
bbrian
Aug 29, 2005 07:47 PM
Visionist
Jul 13, 2003 10:53 AM
