airbag problems??
Old Mar 14, 2004 | 12:30 PM
geedub11's Avatar
Default airbag problems??
how do i disconnect the airbag to change my steering wheel????
geedub11's Avatar
Default Re: airbag problems?? (geedub11)
i have a 94 cx
Old Mar 14, 2004 | 02:06 PM
97Alex's Avatar
Disconnect the Battery, remove the airbag fuse just in case. Theres a couple bolts in the back of the steering wheel, take off the steering wheel cover and disconnect the airbag.
Old Mar 14, 2004 | 04:10 PM
doublejz's Avatar
Default Re: airbag problems?? (97Alex)
on the bottom of the steering wheel, there is 1 screw on like a door. remove the screw, remove the piece of plastic. On the plastic is a red connector. Remove the connector. disconnect the wheres also where the plastic piece was. Plug the red piece into the airbar wires coming from the airbag. This just disabled the airbag from being set off. Then there are two plastic plugs/slots on the left and right of the wheel. pop them open and you will have two star head bolts. remove them, and your airbag will fall out. Then take the big *** nut off that holds the wheel to the steering column thingy hope that helps
htwitr01
Jul 8, 2010 07:13 PM
Jdmdc4ls
Apr 24, 2006 12:15 PM
haloseven
12
Jun 15, 2005 09:29 AM
killa_lude
Jan 26, 2004 07:04 PM
UndergroundVR-4
Mar 22, 2003 09:57 AM
