Where to buy a 85mm 1 layer headgasket?
Old Mar 14, 2004 | 12:15 PM
douglas_be's Avatar
Default where can I buy a 85mm 1-layer headgasket ?
For NA application , does the 1-layer work , easy leaks ?
Old Mar 14, 2004 | 12:46 PM
onePOINTsix's Avatar
Default Re: where can I buy a 85mm 1-layer headgasket ? (douglas_be)
85MM!!!! jesus thats enough to stroke the motor to like 2.4L! i think you mean .085
Old Mar 14, 2004 | 01:08 PM
Dr Pooface's Avatar
Default Re: where can I buy a 85mm 1-layer headgasket ? (Sideout)
I'd guess he means for 85mm bore. Try Cometic.
Old Mar 14, 2004 | 01:16 PM
douglas_be's Avatar
Default Re: where can I buy a 85mm 1-layer headgasket ? (Dr Pooface)
YES bore 85mm 1-layer .009
Old Mar 14, 2004 | 02:21 PM
ahh gotya our local shop VT only uses cometic head gaskets, used one in the 700hp dart honda buildup in Honda Tuning so i will say they are good
Old Mar 14, 2004 | 04:36 PM
00 FBP ItR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">85MM!!!! jesus thats enough to stroke the motor to like 2.4L! i think you mean .085 </TD></TR></TABLE>
x100000000
85mm = 2.4L ??!? What size crank? 100mm?
86mmx95mm BARELY = 2.2L
Who builds your motors?
Now back to the topic... cometic or GE can set you up.
Old Mar 14, 2004 | 04:51 PM
ZygSpeed's Avatar
Default Re: where can I buy a 85mm 1-layer headgasket ? (00 FBP ItR)
Please find/post a good source or website for these Cometic gaskets.
Old Mar 14, 2004 | 10:37 PM
Rob Dizzle's Avatar
Default Re: where can I buy a 85mm 1-layer headgasket ? (zygspeed)
im pretty sure that the distributor for cometic is somewhere in so cal
so im guessing, ge, rs machines, exospeed, earl (laskey), track masters, import builders, or spark racing (am i forgetting anyone) should be able to get them
i would call up trackmasters first, eric is a cool guy that is on top of things, not that eveyone else isnt though.
Old Mar 15, 2004 | 05:06 AM
b19coupe's Avatar
I get my Cometic head gaskets from R & D Dyno Service in Gardena, California.
http://www.rddyno.com/prod/home.shtml
Old Mar 15, 2004 | 05:37 AM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Please find/post a good source or website for these Cometic gaskets. </TD></TR></TABLE>
I think he can search/google for that info.
spunautosports
Engine Machining & Assembly
10
Jan 13, 2020 11:11 PM
hondaman93
Jul 29, 2007 05:08 AM
A_P_1
Jul 26, 2007 01:46 PM
PogKai
Aug 29, 2005 09:26 AM
roadawg
Aug 14, 2003 09:28 AM
