H22 motor swap
Old Mar 14, 2004 | 08:24 AM
NSTY Z33's Avatar
Default H22 motor swap
Well here's the deal. I plan on swapping a H22 soon to my del sol. With it i plan purchasing hasport motor mounts. I know the swap will be a tight fit but the hasports seem to hold it on tight and offer equal clearance sides/front/back. Except the whole motor swap package, what else will i need?? Has anyone done their swap before? I plan on doing it myself but i don't know if it can be possible.
Old Mar 14, 2004 | 10:20 AM
Maddox's Avatar
Yea I helped a guy that did a h22 in a del sol.. It was not that hard.. The only problem that we had was were we were going to put the shifter cables.. We cut 2 1 inch holes thought the firewall and stuck them though. You could go smaller then 1 inch if you wanted to get a tigher fit. The wiring was not that hard at all just had to extend some of the wire, and run a new alternator wire since it is a lot longer then the stock del sol one. PM me if you some details. Good luck.
jerryscherry
Feb 8, 2010 05:47 AM
Burnt Toast
Nov 26, 2007 09:36 AM
zectasy
Sep 21, 2004 04:23 AM
DELshow
Dec 27, 2003 01:20 PM
WuWarrior
Aug 26, 2002 09:23 AM
