Air Compressor / Tools ?
Old Mar 14, 2004 | 06:39 AM
mjrage's Avatar
Default Air Compressor / Tools ?
How many PSI should your air compressor be to put out enough pressure to turn suspension bolts etc?
Old Mar 14, 2004 | 06:44 AM
jaxle's Avatar
um.. impact guns run at 90psi. run your air tools at what the manual tells you to run them at.
Old Mar 14, 2004 | 07:12 AM
mjrage's Avatar
Default Re: (jaxle)
I dont own either so thats why I am asking.
Old Mar 14, 2004 | 07:24 AM
Chiovnidca's Avatar
Default Re: Air Compressor / Tools ? (mjrage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjrage &raquo;</TD></TR><TR><TD CLASS="quote">How many PSI should your air compressor be to put out enough pressure to turn suspension bolts etc? </TD></TR></TABLE>
It depends more on the tool itself. Our shops compressors are set at 150 psi.
Modified by Chiovnidca at 11:35 AM 3/14/2004
Old Mar 14, 2004 | 07:28 AM
jaxle's Avatar
to run an impact wrench your going to atleast need a compressor that can do 4.0cfm at 90psi.
any impact rated at 200ft/lbs or higher will get almost everything out.
Old Mar 14, 2004 | 08:32 AM
doublejz's Avatar
Default Re: (jaxle)
air tools usually saw 90 psi, like Chiovnidca said, mine don't move from 150 psi
UserX826
Paint and Body
11
Feb 18, 2009 09:45 AM
VTECth1s
Paint and Body
May 10, 2007 08:28 AM
AZNracerx1989
Dec 26, 2005 07:32 PM
Chase Taylor
Apr 24, 2004 07:29 PM
dabrown
Mar 15, 2004 09:01 AM
