Dart block question
as with any new block, it should be honed for proper piston-to-cylinder clearance, even if it comes bored to, say, 84.5mm and you have 84.5mm pistons.
Mine was completly unfinished, needeed a bore and hone. But they have changed a few things since then. IM Moxie here on htec, he works for Dart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone »</TD></TR><TR><TD CLASS="quote">Mine was completly unfinished, needeed a bore and hone. But they have changed a few things since then. IM Moxie here on htec, he works for Dart.</TD></TR></TABLE>
what he said.
what he said.
Oil passages should be ok. After honing, you should always clean the block, and inspect all holes and threads. Be sure to tell your machinist to finish hone the cylinders with a torque plate installed on the deck.
allright another quick q's, with a tall dart block can you run a longer rod with a stock stroke b20 crank or is the displacement of the block based on a b16/b18 with over bore? just toasted my b20 block from hydrolock/rod failure and need a few things cleared up before the credit card gets swiped.
water sucks
water sucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moxie »</TD></TR><TR><TD CLASS="quote">Oil passages should be ok. </TD></TR></TABLE>
Have you changed things since I built my Dart? Because my oil passages were far from "ok"
i just got a b16a dart block and it was bored to 80.75mm so that my machine shop could finish bore and align hone my block to the right tolerances for the pistons i was using. I believe all dart blocks come with a .25 to .5mm or extra material to make sure you can bore your cylinders perfectly and make sure they are all in alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbosol »</TD></TR><TR><TD CLASS="quote">i just got a b16a dart block alignment.</TD></TR></TABLE> Dart makes a b16a block now?
I would definitely have it bored to match your pistons. You will need to have it tanked and run thru the washer. Remove all plugs to clean excess casting and machining slag then hondabond every plug. If there is any way to have the oil and coolant system pressurized before you assemble it then you best do it(trust me). You better take your time checking it thoroughly before you assemble it(trust me).
Sorry for the delay, I have been traveling for work. Please let me know what issues you had with the oil passages, and I will check with the block dept. to see how they have addressed them.
Ok, or email me at gwold@dartheads.com. I will be on the road again from Thursday until Tuesday of next week. I will follow up as soon as I return. Thanks.
With sleeves inserted, no. You can't go past 85mm. You could remove the sleeves and have a nikasil (nickel and silicon carbide matrix coating) coating applied. This is thin enough to allow a 87mm bore. Keep in mind that this is very expensive, and probably not worth it. Even with a 95mm stroke, increasing from a 85mm to 87mm bore only increases displacement by 6.37 cubic inches, or about 0.1 liters. There are better ways to spend your money for increased power.
InsertCleverSN
Apr 27, 2003 06:41 PM
