hole in oil pan!?!?>! JB weld?
Old Mar 13, 2004 | 11:46 PM
CleanHatch's Avatar
Default hole in oil pan!?!?>! JB weld?
well, i hit the little damn pointed man hole thing on the road and it put a hole in my oil pan, im wondering if i can just use jb weld??? or i have to replace the whole oil pan?
thanks!
Old Mar 13, 2004 | 11:48 PM
MrIllegalX's Avatar
Default Re: hole in oil pan!?!?>! JB weld? (CleanHatch)
I've seen people JB Weld their blocks....the block of their engine. Sure it can be a temp. solution but go ahead and order a new one.
Old Mar 13, 2004 | 11:52 PM
HyBriDcxR's Avatar
I would just go get a new one. Or hit up the junkyard.
Old Mar 14, 2004 | 12:25 AM
Nerologic's Avatar
Default Re: hole in oil pan!?!?>! JB weld? (HyBriDcxR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyBriDcxR &raquo;</TD></TR><TR><TD CLASS="quote">hit up the junkyard.</TD></TR></TABLE>
Old Mar 14, 2004 | 12:41 AM
B and B's Avatar
Loved
Community Favorite
It could be brazed with an acetylene torch rig.
...or junkyard for clean rebirth
Texas hatches
Mexico Rally today on Speed
Old Mar 14, 2004 | 04:53 AM
WalkingKenshin
Guest
Posts: n/a
Default Re: hole in oil pan!?!?>! JB weld? (B and B)
Old Mar 14, 2004 | 05:18 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanHatch &raquo;</TD></TR><TR><TD CLASS="quote">well, i hit the little damn pointed man hole thing on the road and it put a hole in my oil pan, im wondering if i can just use jb weld??? or i have to replace the whole oil pan?
thanks!
I used jb-weld to seal my turbos oil return line. The stuff works great if you get the surface completely clean.
Old Mar 14, 2004 | 10:16 AM
00EM1Si's Avatar
Default Re: hole in oil pan!?!?>! JB weld? (Chiovnidca)
Same thing just happened to me about 4 days ago...I was going home from the Canyons and then while making a right turn a huge fu*cking rock was on the road and I had no time to react to it and I ran it over which made a hole on my oil pan....I was thinking of using the JB weld but people say its good for temporary use... So I just went to local shop and have them weld it professionally for 10 bucks....and it hasn't leaked since....hope this helps
Old Mar 14, 2004 | 10:46 AM
boostedcivichatchbacksi's Avatar
Default Re: hole in oil pan!?!?>! JB weld? (Krazipeenoi)
JB weld, its a life saver, i used it on my oil return line to the turbo and to the pan, and i used it on the edge of the pan cuz i got my new gasket in there and it leaked cuz i didnt cross torque it lol but yeah, i also used it on some of my charge piping, to patch the leaks in my stupid IC. It hold up very well to heat, i had some of it on the manifold and it didnt burn off, but make sure to use the good jb weld not the quick dry **** that **** burned off my manifold and made a shitload of smoke.
Old Mar 14, 2004 | 10:53 AM
PriMaTe's Avatar
Default Re: hole in oil pan!?!?>! JB weld? (boostedcivichatchbacksi)
I don't know how much an oil pan is but i'd assume it's cheap insurance to just get a new or used one without a hole in it so you don't have to worry about it. i guess its good for a tmep fix
Old Mar 14, 2004 | 02:29 PM
wsiracerz's Avatar
Default Re: hole in oil pan!?!?>! JB weld? (PriMaTe)
u can jb weld it for the time being but i would go get a new one at a junkyard, jus so ur not scared everytime u scrape thinkin it gonna crack again or bust
Old Mar 14, 2004 | 02:50 PM
DumpedSi's Avatar
what pan? I might have one to sell to you
Old Mar 14, 2004 | 04:25 PM
dc2widebody's Avatar
jus buy one from junkyard or order new one.. no need to rig
Old Mar 14, 2004 | 11:39 PM
CleanHatch's Avatar
Default Re: (Slammed Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed Si &raquo;</TD></TR><TR><TD CLASS="quote">what pan? I might have one to sell to you</TD></TR></TABLE>
oil pan.
ok doesn anybody know any d-series oil pan will work?? b/c its basically the same block??
Old Mar 14, 2004 | 11:45 PM
94_HATCH's Avatar
JB weld is only a temp fix but will work. Buy a good used one or save for a new one
Old Mar 15, 2004 | 12:13 AM
liam821's Avatar
25 Year Member
Default Re: hole in oil pan!?!?>! JB weld? (94_HATCH)
You should really get a new one. Because if you do JB weld it and it starts to leak and you run out of oil and blowup your motor; your gonna feel really stupid for not buying a $30 used oil pan.
liam
Old Mar 15, 2004 | 07:08 AM
DumpedSi's Avatar
Default Re: (CleanHatch)
oil pan.
ok doesn anybody know any d-series oil pan will work?? b/c its basically the same block??</TD></TR></TABLE>
no **** oil pan, BUT what kinda of motor?
Old Mar 15, 2004 | 07:23 AM
JDM-97CX's Avatar
thanks!
So you hit a pointed manhole? Make a report and call the DOT, you never know, they might just pay for it to be replaced.
Old Mar 15, 2004 | 08:04 AM
stackz's Avatar
at the jetties fishin'
Community Builder
no **** oil pan, BUT what kinda of motor?</TD></TR></TABLE>\
gahahahaah....hehe
that was some funny ****.
y7/y8's use an aluminum oil pan that isn't interchangeable with the earlier steel pans. as far as I know all the steel pans are interchangeable.
iukaman
Jan 12, 2008 06:39 PM
blackccoupe
Nov 9, 2007 02:25 PM
theharlequin
Mar 5, 2006 01:46 AM
Novtecdohc
Aug 31, 2005 04:29 PM
AgentJam
10
May 7, 2004 03:53 PM
