Might need a new tranny? GSR/Si?
Old Mar 13, 2004 | 06:11 PM
Drian's Avatar
Default Might need a new tranny? GSR/Si?
I have a '94 GSR...2nd gear grinds on high rpms and forget about downshifting! Wondering if Si trannys are good? Don't know the gear ratios n such? Any help is appreciated. Peace!
Old Mar 13, 2004 | 06:33 PM
Yambor's Avatar
Default Re: Might need a new tranny? GSR/Si? (Drian)
si tranny gears are the same as the ITR just without lsd..
Old Mar 13, 2004 | 06:39 PM
Drian's Avatar
So the Si/b16 tranny will be better?
Old Mar 13, 2004 | 06:48 PM
Dan GSR's Avatar
Default Re: (Drian)
acceleration will be better
Old Mar 13, 2004 | 07:46 PM
Drian's Avatar
Hmmmm. I have a '94 GSR so that is a cable tranny correct? So I should find a b16 cable tranny also huh? Any insight on this will be appreciated Thanks!
Old Mar 13, 2004 | 10:44 PM
BuddyClubDC2's Avatar
Default Re: (Drian)
NO, 94 GSR is hydraulic. a ll 94+ tegs are hydraulic
Old Mar 13, 2004 | 10:49 PM
nY's FiNeSt's Avatar
Default Re: (BuddyClubDC2)
keep your gsr, it's the best all around tranny if u plan on NA/FI
Old Mar 14, 2004 | 01:53 PM
Drian's Avatar
Ahhh. Ok Hydraulic. Why is the responses 50/50? Opinions or facts? Thanks!
Old Mar 14, 2004 | 02:23 PM
Default Re: (Drian)
the b16 tranny will top out too quick, if you do alot of highway driving you'll be riding in high rpm's...the gsr is geared so it's not too long or too short
i had an LS and it was too god damn long, then i went with a gsr and it was perfect, great acceleration but yet was good for highway driving
Old Mar 14, 2004 | 02:29 PM
SecretAznMan4u's Avatar
Default Re: (nY's FiNeSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drian &raquo;</TD></TR><TR><TD CLASS="quote"> Why is the responses 50/50? Opinions or facts? Thanks!</TD></TR></TABLE>
because those 50 percent also think that APC is a real tuning company YO!!
Old Mar 14, 2004 | 02:54 PM
Kendall's Avatar
Are you looking at just replacing the tranny with something else that works, or are you looking for a genuine upgrade from what you have? Also, are you on the highway much, and if so do you care about cruising at high rpms? These questions and more need to be answered before anyone can genuinely help you with your decision.
Old Mar 17, 2004 | 12:53 PM
SiR2kingEG6's Avatar
the si tranny has gears to small.. you will top out quick but your gs-r has torque and the si tranny was made specifically for torqueless b series.. that way b16 motor wont come below 5200 rpms when racing.. it is almost the same as if you get the b16 motor with the ls tranny.. rpms will drop significantly when racing due to high gears.. i would say stick with your gsr tranny.. gsr tranny is better for motors that have a bit more torque
Old Mar 17, 2004 | 01:34 PM
Drian's Avatar
Thanks ALL. Sup Roman?
nengx07
14
Feb 12, 2009 11:08 PM
touintegra1
May 8, 2006 07:18 PM
oMek
Jun 11, 2004 05:16 PM
RacerSi
Jan 5, 2004 03:30 PM
