95 b18c into 92 civic hatch si
Old Mar 13, 2004 | 05:49 PM
Lance92Hatch's Avatar
Default 95 b18c into 92 civic hatch si
OKay...swapped a 95 gsr into my 92 hatch....car drove fine at first. After about 10-15 min, car cut off. Started car back up and took to the house (2 min. drive) car would then start up, idle for a few seconds, then cut off.
Changed distributor, but car still cuts on, then cuts off. Car will not start when warm. I'm using the gsr ecu, and the only error codes i'm getting are 23 (knock sensor) and 41 (o2 sensor), neither of which are installed, but shouldn't make a difference b/c the engine should run....
anyone have any suggestions as why the car won't start when warm? When cold the car starts for about 2-5 min, then cuts off and will not restart. thanks.
Old Mar 14, 2004 | 03:02 PM
benhatch101's Avatar
make sure you have no loose connections
Benjamin Caley
Dec 21, 2016 05:40 AM
hafast
15
Jun 3, 2011 04:26 PM
theravine
Dec 3, 2008 09:51 AM
Lance92Hatch
Mar 14, 2004 03:44 PM
