Quick question about Skunk2 Intake Manifold.
This bracket isn't carried over to the Skunk manifold, correct?
I'm in the process of swapping over all the necessary parts. Since the GSR manifold is so heavy, I'm guessing the bracket is needed to support it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TEG »</TD></TR><TR><TD CLASS="quote">OT, is this a pretty good upgrade, worth the money?</TD></TR></TABLE> if your engine has basic bolt ons and if you plan to upgrade cams , etc. Then yes it is worth it .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Definately worth it. Get an ITR tb with itr cams
Cool, thanks guys.
Can't wait to get everything back together. This time around, S2S1 cams, valvetrain, p&p head, 3 angle valve job, milled, decked, oversized B16 pistons, inlinefour TB, Hondata, etc...
Should be a fun summer.
</TD></TR></TABLE>Cool, thanks guys.
Its worth it even on a bolt-on car, i gained 8+ at the wheels with it. Blazin i can't say i am fond of your avatar, but its a free country.
y does every1 say get itr cams? i have seen name brand cams with low miles for the same price. its like u want the persons car to be slow. look around and get some stage 2's. if you get new cams and dont have a lumpy idle you wasted time and money. actually itr tb isn't all that great of a deal either. i paid 90 for a gsr had it taper bored to almost the same specs as an itr one. mine is 65.5mm at the mouth and either 58 or 60 at the im.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE »</TD></TR><TR><TD CLASS="quote">y does every1 say get itr cams? i have seen name brand cams with low miles for the same price. its like u want the persons car to be slow. look around and get some stage 2's. if you get new cams and dont have a lumpy idle you wasted time and money. actually itr tb isn't all that great of a deal either. i paid 90 for a gsr had it taper bored to almost the same specs as an itr one. mine is 65.5mm at the mouth and either 58 or 60 at the im.</TD></TR></TABLE>
To get the most out of the skunk2 stage 2's, you're going to have to raise your compression alot. I'd say 11.5:01-12.0:01 at the least. Raising your compression that high requires you to change out the pistons, in which case, you'll be spending lots of money on parts and especially labor. Quite a difference from just swapping out cams if you ask me.
People suggest ITR cams because they're OEM quality and they provide great gains when tuned properly. If you have a stock gsr block, i wouldn't go more then skunk2 stage 1's/ctr/itr cams. I've seen lots of people put out shitty numbers because they thought slapping in bigger cams meant more power.
I wouldn't get the skunk2 manifold if you don't plan on getting cams. The gsr manifold really puts out great midrange power over the skunk2. You might not notice it now, but you will once you put the skunk2 manifold on. Also, if you don't have any tuning devices, it will really mess up your powerband. If you think your car feels pretty gutless in the low end, it will feel like a geo metro with the skunk2 manifold until around 6000 rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slooogsr »</TD></TR><TR><TD CLASS="quote">well i got my 00' itr cams with 14k miles on them for 300 bucks......... i think i got a good deal.
you guys think i will make out ok with the itr cams and stock gsr IM? </TD></TR></TABLE>yea i have itr cams in my gsr right now with just 2.5 exhaust and an apex filter.. car runs strong.. pulls nice in midrange and topend. skunkstage 2s are gonna get get dropped in pretty soon with ctr pistons etc.!~good luck
MigsD16
Apr 17, 2017 09:28 AM
revolt_allmotor
Welding / Fabrication
10
Mar 23, 2005 03:19 PM
