97' LS MOTOR!!!! Do I use, GS-R, SI, LS , TRANNY?!?! WHICH ONE!
Ok well maybe I don't have enough money for a Type-R tranny, but other than that which one should I use?
I got a JDM YS1 Tranny on my car right now, which is a cable tranny for a 92' engine which is also cable....
I am puttin in my 1997 LS motor in my car soon, but I want a different tranny cause my JDM is grindin in 3rd, So my question is :
I have around $400.00 to spend, I need a HYDRO tranny......Even a freakin LS would be fine, but I need to know which one to get....and which ones years, etc would work....thanks all....peace
pretty cheap like 400-600, if you are going na stay with a y21 if your doing a charger or a blurbo get a ls tranny.
OK, cause Im going Allthrottle Allbottle with this new 97 motor, 125 shots to be exact of N20, just need a better tranny that ratios are a bit shorter to get me up the rpm range where i can get the most outta the internals
OK i think imma go for the B16, they are relatively Cheap as well...
ONE MORE THING!
My Motor is Hydraulic Tranny, what If I use a CABLE tranny? Will I have to change anything? Im more use to CABLE Trannys and they are a lot MORE INEXPENSIVE
ONE MORE THING!
right now i've got a ls. i don't like it. with my raised rev limit i have actually been through the traps still in 3rd gear. (my turbo doesn't make power that high though, i was just ****** around). i will be running a hybrid tranny next year. i know some guys that run around 250-270 to the wheel. one is probably closer to 250 and runs an itr tranny. the other is 270 ish and runs a b16. these guys are running slicks and rev to 8200 rpms. imo, for an ls (only 125 to the wheels), 7800 rpm's if you dare, and lets say a 100 shot, street tires(depends on diameter) a gsr tranny or b16 would run good.
just my experience/opinion.
Sahwn
21
Jul 21, 2005 12:26 AM
