mini-me and distributor
Old Oct 18, 2001 | 03:59 PM
sicivic's Avatar
Default mini-me and distributor
Everyone that has done the mini-me swap, how did you attach the distributor?
One of bolts isn't even close to lining up. Do I mount it with only two bolts? Let me know.
Old Oct 18, 2001 | 06:54 PM
hybridmike's Avatar
Default Re: mini-me and distributor (sicivic)
you will have to notch it , as in cutting one side so you can have more adjustment
Old Oct 18, 2001 | 07:39 PM
asnx6pac's Avatar
I just drilled out the top hole on the distributor bigger and put it on advance as far as possible. It's only on the one top bolt. You can't really tell the timing without a timing light.
Old Oct 21, 2001 | 11:19 PM
89hybrid's Avatar
Better to use brackets. I made some from aluminum.
skhell
Jan 16, 2018 11:37 AM
honda_crv_2000
Honda CR-V & Element
Jan 16, 2015 01:14 PM
z7rix
Oct 9, 2013 10:56 AM
Si_chRis
Sep 13, 2006 03:45 PM
RA61825
Mar 12, 2006 02:26 PM
