fuel system reccomendation??
Old Mar 13, 2004 | 07:45 AM
hondaZvic's Avatar
Default fuel system reccomendation??
im gonna beef up my fuel system by a little bit...
this is for a 2000 h22a4, mods include: short ram intake, and 2.5" piping from cat back with a apexi N1.
i have an apexi VAFC and a walbro255 pump (neither of these are installed yet)
now what kind of injectors and fpr would you guys reccomend?
thanks
Old Mar 13, 2004 | 08:13 AM
homesauce's Avatar
Default Re: fuel system reccomendation?? (hondaZvic)
If those are the only mods you plan on doing for a bit, the fuel system u have now is just fine. You don't need bigger injectors with those bolt ons.
Old Mar 13, 2004 | 08:32 AM
NXLude's Avatar
you wont need bigger injectors for anything NA (that isnt really crazy). You dont even need the fuel pump.....most fprs are the same basically, its up to you. I have the weapon R which I like, mostly because the guage is on the fpr which is really convient for adjustments
Old Mar 13, 2004 | 09:25 AM
Kal's Avatar
Kal
Default Re: (NXLude)
aem fuel rail and regulator is a pretty good combo
Old Mar 13, 2004 | 10:00 AM
thehondaguru's Avatar
Default Re: (kxkal)
Yeah but you really dont need that fuel pump at all. and you have noneed for bigger injectors. Put that money into a nice header. It'll be alot better for you than adding to your fuel system, since you doont need it. DO NOT BUY A DC HEADER!
Old Mar 13, 2004 | 10:12 AM
prelude-bb3's Avatar
Default Re: (95 lude)
why dont DC???
i get 1 in a month or so,chromed and with a good finish...i saw much on fotos of it and it looks in and out better then most others,its a bit smaller but i only run a SOHC lude
Old Mar 13, 2004 | 12:21 PM
hondaZvic's Avatar
Default Re: (prelude-bb3)
actually, i do need that fuel pump. my engine is in a civic... so i have a stock civic pump pushing an H....
and i would rather not buy a header cause im planning on going turbo this summer.. so eventually i will need this fuel system...
the only injectors i've heard about are Venom, Accel, and then RC.
arent stock ludes 240cc? if so then what would be a good step up from that? i dont mind getting something big enough that will be good enough for my turbo setup when it comes.. i just dont wanna get anything to big for now.. thats why i want the regulator.. so i can sortof control it...
any more suggestions?
Old Mar 13, 2004 | 01:02 PM
homesauce's Avatar
Default Re: (hondaZvic)
If u plan on going turbo this summer then wait till then to get the injectors...that way ull have a better idea of how big of injectors ull need. Right now, its imprudent to buy that stuff, just get the pump.
Old Mar 13, 2004 | 01:52 PM
Default Re: (homesauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce &raquo;</TD></TR><TR><TD CLASS="quote">If u plan on going turbo this summer then wait till then to get the injectors...that way ull have a better idea of how big of injectors ull need. Right now, its imprudent to buy that stuff, just get the pump.</TD></TR></TABLE>
Exatly, what I was tryingto say. Sorry about the fuelpump its a good point you got there. I really wouldnt change any injectors till you need them.
Old Mar 14, 2004 | 03:05 PM
SMOOTH97LUDE's Avatar
The stock injectors are 240's. Buy a set of 370's because anything over 440's can not be controller by the vafc. the 370's should work for around 8 psi of boost.
Old Mar 14, 2004 | 03:25 PM
PrecisionH23a's Avatar
Default Re: fuel system reccomendation?? (SMOOTH97LUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMOOTH97LUDE &raquo;</TD></TR><TR><TD CLASS="quote">The stock injectors are 240's. Buy a set of 370's because anything over 440's can not be controller by the vafc. the 370's should work for around 8 psi of boost. </TD></TR></TABLE>
Stock h22a4's are 280cc. If recommend buying a pair of dsm 450's. Cheap and very effective with the v-afc hack.
Old Mar 15, 2004 | 09:20 PM
hondaZvic's Avatar
Default Re: fuel system reccomendation?? (PrecisionH23a)
precisionh23a, do u have some more info on the vafc hack? i've heard a lil about it.. but not enough..
Shoey
Feb 22, 2010 11:22 AM
big juan
Oct 29, 2005 06:59 AM
kaoss_11
Oct 22, 2004 09:43 AM
QCKGSR
Dec 21, 2002 06:41 AM
