B20VTEC machining
Old Oct 18, 2001 | 03:23 PM
ultraspeed2nr619's Avatar
New User
Default B20VTEC machining
i am getting ready to drop off all my parts fer my B20VTEC monster on monday... what all machining do i have to do to the block>> im not too clear about it but for some reason i think that theres something that has to be drilled or the dowels enlarged or something....?? i know about the pistons clearance(valves) etcetc.. i just need DETAILS>.. as far as mating the head to the block...
Old Oct 18, 2001 | 04:02 PM
976's Avatar
976
New User
Default Re: B20VTEC machining (ultraspeed2nr619)
What engine? B20A3 or B20A5?
Old Oct 18, 2001 | 04:23 PM
New User
Default Re: B20VTEC machining (B21A)
niether>>>>B20B with a B16A head>>
Old Oct 18, 2001 | 06:15 PM
976's Avatar
976
New User
Ah, the short term engine codes are the same...
Old Oct 18, 2001 | 10:14 PM
GZR4DR's Avatar
Little help for ya, dont machine anything on the block. Only machine the head. As in enlarge the holes on the head, not the block.
Old Oct 18, 2001 | 10:59 PM
New User
Default Re: B20VTEC machining (GZR4DR)
rite i figured that out now....BUT i need DETAILS... i found an old import tuner article i was looking for.. it says to enlarge the dowel pins on the head to move them so they fit but WHICH n WHERE>. which dowel pins do i use and where do i move them.. where can i find out more about it.. i knoe its the same as an LS/VTEC buildup... i KNOE that CRVTEC.COM and B20_net.com doesnt have any specifics on it.. i need DETAILS...thanks
Old Oct 19, 2001 | 05:17 AM
Daemione's Avatar
You could try running a search over on the boards at http://www.theoldone.com
Just don't post anything, or you'll probably get bitched at. They're pretty touchy over there.
Old Oct 19, 2001 | 07:33 AM
HXMan's Avatar
Default Re: B20VTEC machining (Daemione)
You need details? Check this link. It shows an LSVTEC conversion, but the b20vtec will be the same.
http://www.c-speedracing.com/howto/lsvtec/lsvtec.html
Old Oct 20, 2001 | 01:21 AM
New User
Default Re: B20VTEC machining (HXMan)
COOL!!>. perfect brah....thats EXACTLYwhut i needed...hey you want a b20b head??i have one.. its junking up my house...
CHEESEYeg6
May 29, 2012 08:26 PM
crazyboy
May 1, 2010 11:27 PM
trakwhore
Apr 7, 2008 10:16 AM
af97civic
Jun 6, 2003 06:48 PM
