Am i in deep sh#t?
Old Mar 12, 2004 | 07:34 PM
brickonwheels's Avatar
Default Am i in deep sh#t?
Is there any way to run two dual voice coil subs at 4 ohms bridged or on two channels at 2 ohms a piece? Or, will it hurt a sub at all running it at 4 ohms when it is meant for 2?
Old Mar 12, 2004 | 07:36 PM
Toda Built's Avatar
Default Re: Am i in deep sh#t? (brickonwheels)
try the audio forum
Old Mar 12, 2004 | 08:35 PM
Smeeg Heed's Avatar
if you run 2x4ohm subs in parallel that will make their overall resistance 2ohms. so yes you can bridge to channels to do that. might strain the amp a bit though.
Old Mar 12, 2004 | 08:49 PM
zilverz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brickonwheels &raquo;</TD></TR><TR><TD CLASS="quote">Is there any way to run two dual voice coil subs at 4 ohms bridged or on two channels at 2 ohms a piece? Or, will it hurt a sub at all running it at 4 ohms when it is meant for 2?</TD></TR></TABLE>
the lower the Ohms the more power it drains from the amp.
if you have (2) 2ohm DUAL voice coil subs each voice is 2ohm then the correct way to wire them for 2ohm would be a series that will keep the ohm load on the amp at 2
http://www.installdr.com/TechDocs/999016.pdf
zilverz's Avatar
Default Re: Am i in deep sh#t? (zilverz)
if your amp can not stay at 2ohm stable ... and you only have 2ohm subs .. yea its not going to work
Old Mar 12, 2004 | 08:50 PM
Kendall's Avatar
Whhhhoooooooossssshhhhhhhh.
&lt;the sound of this thread flying way over my head&gt;
PiNoYxRaCeRxRH88
Audio / Security / Video
11
Nov 26, 2005 10:35 AM
Synergy001
Jun 26, 2005 05:14 PM
h22accordr
Jun 6, 2004 12:02 AM
brickonwheels
Mar 13, 2004 12:26 PM
Itz Darave
17
Jul 19, 2003 01:30 PM
