can i use my B18b(obd1) sensors, or my B18a(obd0) sensors on my B18c1?
Old Mar 12, 2004 | 06:02 PM
1SIKCRX's Avatar
Default can i use my B18b(obd1) sensors, or my B18a(obd0) sensors on my B18c1?
when i got my B18c1. it didn't have any sensors. it does have the vtec soleniod. i'm not sure about the vtec pressure sensor!
but i have all the sensors for the mentioned engines here. can i use them? if so which ones would be the better to use?(obd1?-obd0?)
i'm going obd1 if that helps out!!
thanks
Old Mar 12, 2004 | 08:22 PM
Redline130's Avatar
Default Re: can i use my B18b(obd1) sensors, or my B18a(obd0) sensors on my B18c1? (1SIKCRX)
Most of the sensors are interchangeable. The one sensor that is different (only in design, functions the same) is the MAP. I think the rest will work fine regardless of if they are OBD0 or OBD1.
HondaPartsHero
10
May 3, 2023 05:32 PM
93sir2
Jun 18, 2005 09:25 AM
Exempt
Mar 9, 2005 12:02 PM
1SIKCRX
Mar 12, 2004 06:33 AM
