how to tell when your clutch is starting to go out?
Old Mar 12, 2004 | 03:51 PM
civboy115's Avatar
Default how to tell when your clutch is starting to go out?
my clutch doesnt seem like its gripping all that well. I just bought this car (98 honda civic ex) and it seems weak. Is that just the stock clutch being weak or is it going out? it still grabs every gear and doesnt grind, it just feels very soft and not right.
Old Mar 12, 2004 | 03:53 PM
BauleyCivic's Avatar
Risky Business
Default Re: how to tell when your clutch is starting to go out? (civboy115)
The test is to drive the car at like 5-10mph and then put it in 4th gear...if it stalls out, the clutch is good, if it revs up the clutch is slipping and is ready to go.
Also if you go to redline then shift hard into 2nd, you should feel the clutch slip if its going bad
Old Mar 12, 2004 | 03:56 PM
civboy115's Avatar
Default Re: how to tell when your clutch is starting to go out? (BauleyCivic)
i dont think that mph test will work will it? i have an ex tranny and it has really short gearing, i think it will not die just because of that. And it shifts into 2nd from redline fine..l..i guess its ok...
i still want to add a stage 1 clutch down the road sometime...any suggestions as to what brand to get? just looking for a good street / drag clutch
degooser's Avatar
drive up a steep hill and put it into a really high gear...you'll know for sure...
Old Mar 12, 2004 | 04:10 PM
nub's Avatar
nub
Default Re: how to tell when your clutch is starting to go out? (degooser)
can also try driving in second gear at say 20-25 mph and apply the brakes moderatly while also giving it gas, kinda like power braking an auto trans. watch your rpm's, if your rpm increases while your speed remains the same the clutch is slipping.
Old Mar 12, 2004 | 04:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">The test is to drive the car at like 5-10mph and then put it in 4th gear...if it stalls out, the clutch is good, if it revs up the clutch is slipping and is ready to go.
Also if you go to redline then shift hard into 2nd, you should feel the clutch slip if its going bad</TD></TR></TABLE>
my thoughts as well. i like the 4th gear method on stock cars, and the slam second method on higher performance cars.
Old Mar 12, 2004 | 05:24 PM
honda_S's Avatar
**** this sucks i just did the 4th gear test and now i need a new clutch
Old Mar 12, 2004 | 05:50 PM
HATCHingMN's Avatar
Default Re: (8y61d)
when your tire doesn't chirp like it does before...then you need a new clutch
Old Mar 12, 2004 | 05:57 PM
2lua's Avatar
put the car inforth or fifth gear and take off if the car stall within few second the your clutch is good and if the take off without stall then you need a new clutch.
Old Mar 12, 2004 | 07:30 PM
willyboyK20's Avatar
Default Re: (2lua)
I thought that fourth gear test was to see if your pressure plate was bad.
I know on my y8 tranny, i don't know if it was the clutch but when the car was cold i would engage 1st gear the car would chatter like a ****.
solved that problem with a act xt/ss.
Now my left leg hurts. lol!
Old Mar 12, 2004 | 07:37 PM
civboy115's Avatar
Default Re: (willyboyD16)
well in cold weather right now, it kinda has a humming sound around 2-3k rpm's...idk what that is all about, but once it warms up its fine...
it is kinda a whiirr noise then when i let off the gas and the revs drop naturally it gets softer, but still whirrs.
Old Mar 12, 2004 | 08:06 PM
honda_S's Avatar
i was just about to ask somthin about the wiirrr noise thanks for clearin that up
Old Mar 12, 2004 | 08:12 PM
Street Ghost's Avatar
Default Re: (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">when your tire doesn't chirp like it does before...then you need a new clutch </TD></TR></TABLE>
Unless you have Bridgestone Potenza S-03's with a stock clutch.
Old Mar 12, 2004 | 08:30 PM
specv5150's Avatar
when my clutch was going out, I had that burning smell.....frying my flywheel. Also when i would accelerate, the RPM's would go WAAAAY up then drop when it caught
Old Mar 12, 2004 | 08:50 PM
MrIllegalX's Avatar
Default Re: (93 EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Unless you have Bridgestone Potenza S-03's with a stock clutch. </TD></TR></TABLE>
I deff. can't chirp like before...I went from Avid H4's to Azenis.
Burnout? nah can't do that either. Those suckers grip.
Do what Bauley said, and get a new one anyway, it doesn't hurt.
Go with a ACT clutch kit, and you might as well get a lightweight flywheel while you're at it.
Old Mar 12, 2004 | 08:53 PM
civboy115's Avatar
Default Re: (MrIllegalX)
how much do shops usually charge to change clutchs and flywheels....or is it easy and you can do it yourself...
is there a walkthrough on here? or is it better to pay to have it done?
Old Mar 12, 2004 | 09:09 PM
specv5150's Avatar
Default Re: (civboy115)
the last time I got a clutch/flywheel resurface done, it was around 300. Obviously I took them my own clutch and had the resurface the stock flywheel
Old Mar 12, 2004 | 09:26 PM
civboy115's Avatar
Default Re: (specv5150)
oh ok, cool. So babsically with the ACT clutch im lookin at plus 300 or so bucks for them to do it...total...600 bucks for a new clutch. cool thanks man
JDM_Certified
Transmission & Drivetrain
Oct 7, 2010 08:56 AM
oovvutt
Oct 28, 2007 03:45 PM
manyakiexpi
Apr 6, 2006 01:41 AM
petrv
Aug 17, 2004 02:10 AM
Flux
Nov 26, 2003 11:25 PM
