inner half of front tire bald - tire shop switch it?
Old Mar 12, 2004 | 03:08 PM
slowacura's Avatar
Default inner half of front tire bald - tire shop switch it?
the inner portion of my tires are really worn but the outer has like 90% tread. so when you guys have this, do you take it to the tire shop to have them switch teh right tire to the left rim so you will wear out the other side of the tire? or do you just put the worn out tire in the back with the worn out still on the inside edge of the tire.
Old Mar 12, 2004 | 04:45 PM
doublejz's Avatar
Default Re: inner half of front tire bald - tire shop switch it? (inteGSR)
i would get an alignment and fix your camber, then buy a new tire You can flip them but its just gonna do it again
Old Mar 12, 2004 | 04:59 PM
VsR785's Avatar
id say go buy a camber kit if you've lowered your car and then get an alignment, and finally get new tires
Old Mar 12, 2004 | 05:14 PM
SIK IN DA HED's Avatar
New User
your car must be dumped if its going bald around the inner area of the tire but theres still 90% left on the outer. fix that camber... because you can keep flipping and replacing those tires all you want.. its gonna keep goin bald.
4ndreas
Suspension & Brakes
Jun 13, 2015 04:12 AM
hillbillycivic
Suspension & Brakes
11
Nov 3, 2012 06:37 AM
beanbag
Apr 5, 2009 09:55 PM
-Championship-
Feb 6, 2007 01:08 PM
lowRIDAH
12
Jul 26, 2004 03:16 PM
