Instruction on replacing a motor mount?
ok, well you want to atleast support the motor with a hydraulic jack. and then just unbolt the two 14 mm bolts that hold the rubber mount to the frame. then you unbolt the 17 mm bolt that goes through the rubber mount. and do the reverse to put back on the new mount.
yeah, don't pay the honda dealership to do it for you. it's very easy and theres only like 3 bolts. those bolts might be hard to take off so a good breaker bar would provide some good leverage.
