ITR Gauges fit in Integra??
Old Mar 12, 2004 | 01:13 PM
Franky's Avatar
Default ITR Gauges fit in Integra??
Honda-Tech Member?
I have a 1999 LS and was wondering if a 1998 ITR Gauge Cluster (RPM/Speed/Gas Gauge)will fit? Will the wires just plug in? Or do I need to modify? Any help would be great.
Franky
SuzukaBlueAP2's Avatar
Default Re: ITR Gauges fit in Integra?? (Franky)
are you talking about the guage cluster with the speedo and tach ?
if so, yeah, it'll work.
Old Mar 13, 2004 | 01:06 PM
Yambor's Avatar
Default Re: ITR Gauges fit in Integra?? (ScreaminTeg)
also just a quick question wouldnt the rpms be off since the numbers for the revs are in different locations than the ls? ir is there sumthing to make the actual revs match the gauge cluster..
example.. if i was pulling 6k in my ls wouldnt that show up as i different rpm on the ITR tach?
Old Mar 13, 2004 | 01:18 PM
greekspeed's Avatar
Default Re: ITR Gauges fit in Integra?? (Honda2nr4life)
no because it still gets the reading from the ecu... and what ever reading the cluster gets form the ecu, the cluster will then translate it to the appropriate rpm reading on the cluster.
Old Mar 13, 2004 | 01:21 PM
greekspeed's Avatar
Default Re: ITR Gauges fit in Integra?? (greekspeed)
also u will have to take both clusters (Stock one and ITR one) appart to swap the individual ITR gauges themselves onto the ur stock gauge cluster motherboard make it work right..
so its not a plug and play swap... but not that hard either
Old Mar 13, 2004 | 01:31 PM
slo2kgsr's Avatar
It might be my buddy pluged and played a 00 si cluster in his 95 DX. Dx had no tach pluged in the cluster and the si tach worked and everything.
Old Mar 13, 2004 | 01:33 PM
greekspeed's Avatar
Default Re: ITR Gauges fit in Integra?? (tegraLS97)
ooops.... i was speaking of a JDM ITR cluster swap....i think the USDM ones will swap clean with plug and play.
Old Mar 13, 2004 | 01:39 PM
vegas's Avatar
It still shouldnt matter if its jdm...
i swapped in a jdm and it read the same....
-veg
Old Mar 13, 2004 | 03:06 PM
Sukebei Oni's Avatar
Default Re: ITR Gauges fit in Integra?? (vegas)
i swapped in a usdm ITR cluster into my GSR cluster just fine. everything just plugged right in. But I did swap odometers between the clusters so that i would still have the correct odometer reading.
is your LS an auto or manual?
Old Mar 13, 2004 | 03:08 PM
Kendall's Avatar
It will be plug and play. The only real issues people seem to have is when using the earlier (94-97) clusters with the later cars (98-01) and vice versa. It shouldn't matter if the car is an auto or manual, the cluster should read the same.
Old Mar 13, 2004 | 03:15 PM
Default Re: (Kendall)
yeah, the cluster should read the same I geuss, but doesn't the auto tell you what position the shifter is in on the cluster, I didn't know if it would do it on the ITR one.
Old Mar 13, 2004 | 06:01 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greekspeed &raquo;</TD></TR><TR><TD CLASS="quote">ooops.... i was speaking of a JDM ITR cluster swap....i think the USDM ones will swap clean with plug and play.</TD></TR></TABLE> wrong again...just swap out the green film on the back of the cluster. Please don't pass along false information like this, as someone did to me Have you ever even done a cluster swap or had any personal experience w/ them?
joey funk
Sep 21, 2008 12:30 PM
GuitarSlinger78
Nov 14, 2006 10:56 AM
ptsiu
Jun 15, 2003 07:49 AM
allmotorls95
Feb 19, 2003 03:18 PM
