Injector size?
that would depend on injector duty cycle.. what type of fuel managment are you planning on running.. my original plan was for 200whp n/a with 370's.. i ended up doing that with turbo and duty cycle was like 60 or 80% at 60psi.. but a/f ratio isn't as low with n/a so you might be o.k. with 310's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 »</TD></TR><TR><TD CLASS="quote">also do i have to replace my clips? anyone know where i can get these?</TD></TR></TABLE>
The clips or the injectors?
Same place I'd guess.
yea, im looking for somewhere to buy both, i should have explained myself i guess. maybe someone here has a set, or knows a shop that has some kind of deal going
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">440 may be too big. </TD></TR></TABLE>
No such thing as too big when it comes to fuel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 »</TD></TR><TR><TD CLASS="quote">sgt, will the 310's get the job done up to about 215whp?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drag R »</TD></TR><TR><TD CLASS="quote">
stand alone = 370s - 440s
chipped w/ vafc - 310s max
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">270's will be enough, anything over 310 is overkill.....</TD></TR></TABLE>
totally agree. 310 is all that you need. over that idling issuses can occur and possibly harder to tune
310 the way to go for your power
if you have a standalone go with bigger injectors like 440's because then you can just downtune them and you will not have idling issues I was running 550's on my setup and they were fine now I have 440's though sold my 550's. But if your running a vafc get the 310's
andrewasf77
Mar 12, 2004 08:04 PM
