How do you run the codes in the ECU for 2nd Gen Integ?
How do you run the codes in the ECU for 2nd Gen Integ? My friend said that you COULD put some kind of paper clip on a wire or something... but he could only find that wire in the Civic... does the Integra have the same thing? **** i needa run those codes to find out why my Integra is limiting me... thanks for any of the info
If you remove the plastic panel underneath the dash on the passenger side there will be a plastic connector plug (grey if I remember correctly). Take a piece of wire and put both ends of it in the connector (there will two openings in the plug, one for each end of the wire). On a 90-91, you'll need to read the flashcodes off of the ecu. On a 92-93, you'll read them from the cluster.
BlackHXCoupe
Jan 19, 2010 11:08 AM
Loaded Butane
Feb 23, 2002 05:08 PM
