4th gen driver's side power window won't go down in the morning
Old Oct 18, 2001 | 12:22 PM
doe's Avatar
doe
Default 4th gen driver's side power window won't go down in the morning
the passenger window works fine, and the driver side will work in the afternoon. in the morning, however, the driver side sticks. this happened yesterday morning and today (yesterday it went down, then i rolled it back up, and then it wouldn't go down anymore).
later in the day it works....i think it might be because it is cold in the morning, but i'm in southern california, and its only ~60 degrees at night right now.
any ideas?
Old Oct 18, 2001 | 12:33 PM
Gennady's Avatar
New User
Default Re: 4th gen driver's side power window won't go down in the morning (doe)
Mine squeeks very loudly as it goes down. So I put my hand on top of it, and pull in and down. Try just pushing it down manually. Its due to temperature and moisture.
Old Oct 18, 2001 | 03:15 PM
Honda318dx's Avatar
Default Re: 4th gen driver's side power window won't go down in the morning (Wont be beat)
is the motor running to push the window down?
Old Oct 18, 2001 | 05:33 PM
CardDealer's Avatar
Banned
Default Re: 4th gen driver's side power window won't go down in the morning (Honda318dx)
Modified by CardDealer at 4:24 AM 11/16/2006
Old Oct 18, 2001 | 09:24 PM
smokin rubber's Avatar
Default Re: 4th gen driver's side power window won't go down in the morning (schlit)
spray silicone lubricant in the run channels of your window...it does wonders if you've got friction slowing/stopping the movement of the window
exactly, I used slick 50, but armor all would probably work.
Old Oct 19, 2001 | 04:38 AM
John's Avatar
New User
Default Re: 4th gen driver's side power window won't go down in the morning (smokin rubber)
does anyone's power windows make a loud clank sound when you engage the window motor?
[Modified by DunReit, 9:16 PM 10/19/2001]
Old Oct 19, 2001 | 02:37 PM
dvsOasis's Avatar
4th gen driver's window is notorious for problems...like they become loose and need to be retightened...sometimes the windows go off track....
I've fixed my window like 3 times already, but it's loose again...i'm gonna have to superglue that rubber thing inside
Old Oct 19, 2001 | 02:40 PM
Gennady's Avatar
New User
Default Re: 4th gen driver's side power window won't go down in the morning (DunReit)
My drivers side squeeks, and my passenger side clanks.
Old Oct 19, 2001 | 03:45 PM
John's Avatar
New User
clanking? does it clank when you engage the PW motor? mine does on my 5G, but i wonder if that's a result of moving the window tracks to accommodate for deeper speakers...
mark_is_gay
Sep 17, 2006 06:02 PM
AccordCD5
May 24, 2004 07:32 PM
Philip
Aug 28, 2003 08:45 AM
