HELP a noob with his distributor
Old Mar 12, 2004 | 06:41 AM
XenoPhobe's Avatar
Default HELP a noob with his distributor
Apparently I need a TD# when ordering an aftermarket part. Well, there is no such number on mine; the only number I have is D4T94-05. I took it off and checked everywhere and no luck with a TD#.
I ain't bout to pay $$$ for a reman honda pos when I can get a new one for <$200. PLEASE anyone my dizzy about to die from oil up in it.
96 HX D16y5
Old Mar 12, 2004 | 07:45 AM
XenoPhobe's Avatar
Default Re: HELP a noob with his distributor (XenoPhobe)
ttt
Old Mar 12, 2004 | 08:16 AM
doublejz's Avatar
http://www.andale.com/store?si...atId=
Old Mar 12, 2004 | 08:21 AM
XenoPhobe's Avatar
Default Re: HELP a noob with his distributor (doublejz)
Already been there and talked to them as well as streetimports.com. They can't guarantee that the TD80U will fit a VTEC 96-00 1.6L. So now what??
Old Mar 12, 2004 | 09:04 AM
paybac4223's Avatar
did you check the top wing on the dizzy? usually the TD # is on that bolt... hope that helps....
Old Mar 12, 2004 | 09:16 AM
XenoPhobe's Avatar
Default Re: HELP a noob with his distributor (paybac4223)
the bolt that is at the top of the housing? i wasn't looking on the the bolt per se but rather on the housing. welp, I'll have to look after work but man I took that bad boy off and cleaned and didn't see anything else.
Old Mar 12, 2004 | 09:19 AM
Chiovnidca's Avatar
Here's where they put it. Sometimes it's hard to see.
Old Mar 12, 2004 | 09:21 AM
XenoPhobe's Avatar
Default Re: HELP a noob with his distributor (Chiovnidca)
aight coolio maing. i'll check it after work. wth would they put it right there??
Old Mar 13, 2004 | 10:19 AM
paybac4223's Avatar
yea...what he said[QUOTE=Chiovnidca]Here's where they put it. Sometimes it's hard to see.
Old Mar 14, 2004 | 08:38 AM
XenoPhobe's Avatar
NO LUCK!!! I again took the distributor out and literally searched everywhere for that number. I cleaned it using soap and water and still didn't find a trace of any number anywhere.
Can I assume that all 96-00 Civics (except the Si) use the same distributor TD80U?
Old Mar 15, 2004 | 10:11 AM
XenoPhobe's Avatar
ttt
anyone?!?!?!?!
Old Mar 15, 2004 | 07:48 PM
Qfactor's Avatar
what exactly is wrong with your dizzy, maybe I can help you meng...
apaige58
Mar 24, 2014 10:16 AM
PuroMotor
Jan 9, 2014 12:46 PM
85civic
Aug 14, 2004 12:27 PM
1dopeazn7o2
Aug 14, 2003 12:47 PM
