New problem (after header install)
Old Mar 12, 2004 | 01:35 AM
BlueFang08's Avatar
Default New problem (after header install)
Finaly installed my header and now my car does not start. it has power but it keeps turning over and over. Never starting?
Old Mar 12, 2004 | 03:04 AM
Chiovnidca's Avatar
Default Re: New problem (BlueFang08)
Does it have spark?
Old Mar 12, 2004 | 05:10 AM
Filthy Focker!'s Avatar
Default Re: New problem (Chiovnidca)
Every time a car does not start, you always have to go through the same troubleshooting steps... This has been discussed alot here. But here goes.
To start a car you need - air, fuel, spark, timing, compression
First thing, have you flooded the engine? Slam the gas pedal to the floor and crank to see what happens.
Second, did it start ok before you worked on it? If so, probably a loose connection somewhere.
If this checks out:
1. check to make sure nothing is disconnected under the hood.
2. Check if you have gas in the tank
3. check voltage to battery 12.6 volts or more
4. check for spark at sparkplugs
5. check for fuel by either smelling the throttle body or removing fuel line to filter and crank engine.
Now, you don't lose compression overnight so, you don't need to check this until last recourse.
Someone should post a good no-start troubleshooting guide on this site somewhere.
fs
Old Mar 14, 2004 | 05:44 PM
OG SHG_EM1's Avatar
how do you check for spark
Old Mar 14, 2004 | 05:47 PM
fw190bvi's Avatar
Default Re: (98civicdream)
i believe u can pull the plug, connect the plug to the wire and check for a spark between the electrode when u try starting.....u can at least do that on my snowblower.....
PeterVSays
Dec 29, 2012 10:51 PM
nandito
Nov 9, 2011 08:27 PM
jasko97
Sep 1, 2008 07:36 AM
draw
20
Nov 22, 2004 08:33 AM
JDMflavor_EJ
Mar 26, 2004 11:52 AM
