H22A swap not starting
Old Mar 11, 2004 | 10:26 PM
spoonhatchblack's Avatar
Default H22A swap not starting
I installed a 1997 H22A in my 92 si. I am using a modified prelude distributor (1997 OBD2 converted to OBD1). When I crank the car, it doesn't want to start. It seems like there is something preventing the crank from turning. When I remove the spark plug wires from the distributor and crank the car, it cranks freely. I think that it may be the distributor. Does anyone know what it may be? Has anyone modified the OBD2 distributor to OBD1?
Old Mar 12, 2004 | 10:29 AM
JDMH22's Avatar
Default Re: H22A swap not starting (spoonhatchblack)
Maybe the distributor is done wrong. You can use your H23 one try do that.
Old Mar 12, 2004 | 10:55 AM
Built2.0Lude's Avatar
I would assume you just have some wires mixed up... I would just do what JDMH22 said and throw your obd1 distributor in and then it should work just fine.
Old Mar 13, 2004 | 01:14 PM
yea you were right.
i got one of my buddys jdm dist. and plugged it on and it fired up.
Thanks for all the assistance.
i'll keep you guys posted on how the motor runs and everything.
Angeljavier3577
Apr 30, 2018 01:41 PM
BowtieHonda
Mar 19, 2012 08:15 PM
spoonhatchblack
Mar 17, 2004 10:17 AM
Astr8upfella
Jan 20, 2002 01:30 PM
