H22A wiring and vacuum hose connection
Im doing a H22A swap into my 91 accord........and was wondering if and one can give me some ideas on wiring up the motor. On the vacuum hose from the MAP sensor....do we use the accord MAP sensor or use the H22A MAP sensor? The oil pressure sensor do we hook it to the accord oil pressure sensor wire or run the wire to the ecu? Well if any one can help me it will be greatful..........
